Drove that bad boy to work this morning! What a view! Taking it to the shop on the way home for a Regear!
That's more of a "I'm cool and know it" face.
Just old and ugly now.
My wife always complains about getting old. I tell her, it sure beats the alternative.
p.s. This was my best "smiley face" pic. Camera broke after taking it.
Is that after she smacked you around?
Not sure, but mine was done in 1979, don't think roadkill was thought of then
You better you better you bet
The original roadkill came about when Granny of the Beverly Hillbillys used to make Possum stew for Jethro.
Do you have a link to that molle panel?
How did you mount it?
Does it interfere with the speakers?
Do you have any more pictures?
Hooke Road Wrangler Overhead MOLLE Panel Plate Interior Storage Compatible with Jeep Wrangler TJ Hardtops 97-06 https://a.co/d/iDO29Bs
You have to peel back the cloth cover on the rollbar and remove the Styrofoam padding underneath. It has two clamps that go on the rollbar and that is where you bolt on the t-bracket. The t-bracket has a lip and that is where you place the shelf. Finger tighten everything to make sure you have it lined up correctly and then snug it down. It does not interfere with anything.
If you need them, I will take more pictures tomorrow. I am at night school tonight.
Made some custom brackets for my drop down tailgate
Ordered some OEM style rubber extended brake lines front and back. Last part got delayed to my new springs and it will be here tomorrow so the OME springs 10mm spacers new isolators and bump stops will go on Thursday . Nothing like getting things none the last minute ! Wanted this part of the restore done by the end of this week .....will by the skin of my teeth .
Starting to order the parts to phase II .
Coming up:
Rear Disc
True Trac front and rear
Moly Axles
Steering upgrade
Mounting the winch
Big 5 wiring
Hum ! I wonder when I will be done ??????
Maybe "my Jeep is cool, and I know it"
I haven't been cool since the 80's
Godamn John. Not what I expectEd you to look like. Did you have a burger at the cafe across from Darrell Harp
