Here’s why. They are definitely different sizes.
I generally work on Jeep a few hours a day (before work, lunch break if I can) and spent the last two days saying no way I have to grind this, I’m definitely doing something wrong.
@rasband says grind it. And 5 min later the arm is installed lol
I'd put JJs in the new axle for those uppers.
This is what you’d recommend? https://www.rockjock4x4.com/CE-9102K
I can do on new axle sometime soon then
I have two of just the barrel style, since I don't like the way the tombstone looks (actually, I have that two if you want to buy it from me). Though I have read that those might not have as much movement as the stock clevites due to the joint size. I haven't really looked though since I may never do mine since I plan to midarm eventually.
What are the barrel style? I might be missing where that is on Currie website
Guessing you mean this?
https://www.rockjock4x4.com/RJ-301001-101
Found kit from savvy that looks similar to Currie one.
If I order from savvy now, I’ll be able to install by Christmas!
Got lower arms back in.
Any tips on rotating pinion enough to slide driver side arm in? I thought I could Jack at the front of the coil spring bucket but that didn’t get it quite lined up.
I know I can do with help of a friend but was trying to avoid if possible.
Are you doing it with the weight of the jeep on the ground?
me: has problem
Rasband: fixes problem
