Rock Crawler bumper pulled and the front frame cleaned up.
what primer did you use?
You're gonna be amazed at the handling difference, both on pavement and off.
I forgot you already had one on the TJ. I can't keep up with you!
I'm tired of advertising for companies. Recieved a MC rear differential cover, then took a grinder to remove the "M". FWIW, I picked this cover because it has protection for the bottom bolts, clears the gas tank skid easily, and has a small drain plug. Also cleaned up the area in the process of replacing the cover.
Before
After
Thanks to Jason, @taylormade73 , I've now ordered a Savvy UA and front bumper. Once they come in I'll have Savvy:
- LJ rockers
- Tailgate armor
- Rear valance
- Engine skid
- Cable shifter
- Body Lift
- Control arms
- Steering box skid
- UA
- Front bumper
All that's left is the LJ corner armor and rub rails.
If anyone is looking, Savvy is showing two front bumpers in stock.
Would you be willing to share a rough sketch of overall dimensions and hole locations of the corner guards?Got lucky and received two sets of these from another forum member. Now if the Savvy winch plate would ever show up, I can install the Savvy front bumper.![]()
Fed Ex delivered my Savvy winch plate today. I’m in Northern California. I would suspect you will see yours soon.
Check out @DrDmoney's thread. He made a set for his GR bumper back when the 6061-T6 threads were exploding.I could use the info on those guards too. Hopefully Savvy will have them available by the time I need them but if not, I’ll make them.
