It just happened!
MountaineerTom
Sumter, SC
I made a trip to AOAA last week, where I bent the replacement ZJ tie rod. I'm now convinced that the ZJ conversion is a good street upgrade, but that for wheeling, something heavier duty is needed!
Dang, I'm still on the OEM tie rod and as far as I can tell, it's not bent. I must not be wheeling hard enough. :ROFLMAO:
Where did they bend? Same spot?
SubLime
WI
I did. For anyone interested, here is the entire parts list:
Parts Used
Dorman 69001 Nylon Rib Drain Plug Gasket, Fits M14, 1/2https://www.amazon.com/gp/product/B00NF17LQM/?tag=wranglerorg-20
Dorman 265-818 Transmission Oil Panhttps://www.amazon.com/gp/product/B00Z7O4OVA/?tag=wranglerorg-20
Universal Firewall Boothttps://www.amazon.com/dp/B08LGNDD2G/?tag=wranglerorg-20
LUBE LOCKER LLT-A042https://www.amazon.com/gp/product/B00BOU6UJA/?tag=wranglerorg-20
AUTO METER 2267 Oil/Temperature Metric Adapterhttps://www.amazon.com/gp/product/B00062YVOI/?tag=wranglerorg-20
Mopar 68218057AB ATF+4, 1 Quart (6 Pack)https://www.amazon.com/dp/B07VFJYQJ3/?tag=wranglerorg-20
Genuine Mopar Transmission Filter 68059549AAhttps://www.amazon.com/dp/B00F6E49UW/?tag=wranglerorg-20
MaxTow Double Vision 260 F Transmission Temperature Gauge Kit - Includes Electronic Sensor - Black Gauge Face - Blue LED Illuminated Dial - Analog & Digital Readouts - for Trucks - 2-1/16" 52mmhttps://www.amazon.com/dp/B01MS4HDXC/?tag=wranglerorg-20
so the trans temp gauge fitting just plugs into the drain plug of the new pan?
Reactions: Irun
Irun
Irun
Jeep Addict
Virginia
Sometimes it's the simple things. Dashlights are now a patriotic red, white and blue. And yes, before anyone says anything, I listen to Glenn Campbell! ;)
  • USA Proud
Reactions: John Cooper
Irun
Irun
Jeep Addict
Virginia
I have an excessive amount of brake dust on the driver side. Any ideas what's causing that? The first picture is driver side. Second picture is passenger side.
NashvilleTJ
I miss the snow...
Nashville
You are not placing your foot in the center of the brake pedal, you are pressing to much on the left hand side…
Glad to see the death wobble in your rear view.
mastergunnera8
No. Virginia
Reactions: Wildman and Irun
