Here are my angle measurements on the transfer case and pinion. I checked it with a cell phone app. The driveshaft is 20.2 degrees. So people can check my math. I measured each control arm to make sure the axle is square. Joints are two days old. No impact on the drive shaft so I cant see it being out of balance. I can't figure this out. I thought I had both angle finders on the same zero, but the difference is basically zero.
Did you have the driveline balance checked?
