P
PNW_LJ
Guest
Okay so I know 37s are widely accepted as a huge step up in cost and time to build well but hear me out here. I think what I have laid out as a build plan is reasonable but would like to hear your guys' thoughts before I plop down the big coinz.
What the build is going to look like:
04 LJ
42RLE
Savvy midarm
Highline fenders
Outboarded shocks
JK or JT axle swap w/ 5.38s and ARBs
37s
My initial build plan was to go with the standard 35s build with the savvy midarm and HP30 swap, however, I know I will likely want 37s in the future so might as well do it right the 1st time to avoid buying new axles/lockers/driveshafts/truss etc a 2nd time. With the LJ's worse geometry compared to a TJ, I think 37s are the right tire to help it compete with JKs on 40s that I will be wheeling with. The LJ wheelbase and the increased width/strength of JK/JL/JT axles are just right for 37s as well, IMO.
Yes, I'm mostly aware of the work that has to be done for this swap. Cutting off and welding on basically all new axle bracketry, track bar mounts, steering etc. I've never done an axle swap before myself, but I've done enough work around cars that I think I could figure it out with enough hours spent welding, cycling suspension, cutting off, and rewelding.
My questions are:
1. Does anyone have direct experience with an axle swap like this? How much of a PITA was it to build everything the right way, minimizing bump steer/flexsteer etc?
2. Has anyone done a JL/JT axle swap specifically? They're way beefier than JK axles, but no one offers a swap truss kit for JL axles into TJ as of yet.
3. How bad are the 37s with 5.38s and 4.0 as a daily driver?
So let me know whether this is reasonable or if I'm talking out of my rear end
. Thanks in advance!
04 LJ
42RLE
Savvy midarm
Highline fenders
Outboarded shocks
37s
My questions are:
