Spraying your control arm bushing with WD-40
Jmac00
Lifetime Supporting Member
varies every few weeks
Is it a good idea to spray all your rubber suspension mounts with WD-40? to keep them Lubed up?
it seems to me that would attract a lot of dirt? Is it a good idea or should you use silicone or leave them dry???
Reactions: Jerry Bransford
Separate from the problem of thinking wd40 is a lubricant, what moving parts on the factory bonded rubber control arm bushings need lubrication?
No reason to be condescending to someone trying to learn something. The rubber bushings shouldn't move they are permanently bonded to the control arm. The clamping force on the brackets should keep them from rotating on the axle or frame. There are literally no moving parts to lubricate. With WD-40 or otherwise
how the hell would I know, thats why I asked, hell Im not even sure what a control arm does, Im just trying to get all the squeeks out of the thing
You were being very specific. Now we know this is really about squeaks. Where are they coming from? The control arms?
A spray lithium grease or silicone spray lube would probably do it. They are rubber and not polyurethane? Polyurethane is well known to squeak and its hard to stop its squeaks for long.
Reactions: macleanflood
ok, Im an idiot? what the hell are these called ??? I know they are not the control arms, but Im not sure what these are called ? I tried to get grease in them put the zerk seems to be plugged
  • Face Palm
Reactions: 707kevin and JMT
That is a control arm. That is an aftermarket control arm that uses a split bushing on at least one end. If the grease zerk won't accept grease, then you need to replace the zerk. Or you need to disassemble the split bushing and grease it by hand. Spraying stuff at it won't do anything meaningful.
Reactions: MikekiM and Jmac00
That also looks like the old Teraflex twisty control arm that has a long history of seizing and tearing off control arm mounts even when the middle threaded portion doesn't seize.
  • Wow
Reactions: Jmac00
That's a control arm, specially it's the 1st generation control arm made by Teraflex. The grease zerk itself or the area be it is probably packed with old hard grease.
Reactions: Jmac00
great, I have been beating the crap out of the Tj on these rock, some of the trails are R E A L L Y rocky. I guess I better find some new ones, soon
You can do whatever you want to do. Now you know that those arms have long been known for their poor design.
can I pull that apart and clean up, I assume it need to be a specific length.
It is, probably 2o+ yrs old, LOL
Assuming they are the appropriate length for your rig, all you need is a tape measure before you start unbolting and unscrewing.
Reactions: Jmac00
I think whoever put this Tj together knew what they were doing everything seems to work really well. I replaced the belt, belt tensioner and pully, and the steering damper ( that was fun) the shocks, and all the rubber body mounts.
