Most important issue for the 2006 TJ is the overheating as soon as the outdoor temperatures start hitting the 80s.
Venting / Louvering has been covered thoroughly for the 1997 TJ, but not for the 2006.
The locations for the 1997 heat zone areas seem to be best vented based upon positioning by using the GenRight Off Road hood louvers.
I have not found a full center vent louver panel that takes these zones into account (excluding separate side top vents) along with the major central area, meaning the back section has been excluded just seemingly just to preserve the wind shield bumpers, which I do not care about & never intend to use; I care about bringing down temperatures, preserving wire shielding & plastics under the hood, and making the A/C run superbly. To that end, the first step in even 80something degree heat outside turning into 111 or more under the hood is to vent the heat... The large center vent doesn't seem the utilize the back (close to the wind shield area) & out to the back(wind shield)sides of the center area.
Is there a large center vent that covers the areas I am describing? Most of the ones that I have seen do not.
If you know of one that maximizes vents in the areas closer to the wind shield side along with the main front and center areas, please advise.
I plan to use the side GenRight Off Road top of hood louvers along with a large center option if I can find one to my standards ( :
