Do you remember the bolt head size? Was it 10mm?
13mm
I need to flush the power steering fluid. Yesterday, I pumped out all the fluid in the reservoir and filled it back up with new fluid. I read in these forums to drive it around a bit to circulate the fluid. Then, pump it out again, fill it back up, and you are good to go. How many miles do I need to drive it to properly circulate all the PS fluid in the system? Is 20 enough?
13mm
I may be wrong, but I don't think you even need to drive it around. Just turn the steering wheel all the way back and forth several times and it should circulate that way.
When I changed mine out in the past, I sucked out all I could with a turkey baster, filled it back up, turned the wheel like that several times, pulled it back out again, refilled and called it good.
Ahh, Ares has an individual torque adapter extension for $20 on Amazon and NAPA has one for $16 with free shipping.
https://www.amazon.com/dp/B09DMDMRDH/?tag=wranglerorg-20
https://www.napaonline.com/en/p/CHT...ajLIv9i_45mLx8QNasaAr8JEALw_wcB&gclsrc=aw.ds&
@DB04RedJeep what is FF spraying?
@MountaineerTom good idea on that. I couldn't easily find an individual piece, I don't want to spend $100 on a full set, and I have a light day today. I'm going to finish up my coffee, wait for the after effects of coffee to kick in, and then go start to drop my skid plate.
Don’t tell Zorba you were taking cell phone pics and driving.
I can cross another thing off of the list for this Jeep.
Forgot the pic of the Mammoths. One to many Heineken.
