It's down here in South East Arizona 😁
Very nice. I think we ended up with 8-9 inches. Some parts of the state got 17 inches plus.
My wife and I both like AZ a lot. Have spend time in Chandler, Sedona, Flagstaff and our favorite Jerome. It's been a few years but the next time I would like to go south and west a bit to see those areas.
  • USA Proud
Reactions: RINC
Move here with your Jeep, or come on vacation without it. We love hosting out of towners.
That’s about what we look like here in MN.
It's all the snow that my wife and I like to see at our age. Don't have to drive in snow if we choose not to, and with me being retired and her working from home, we don't choose to drive in it. It's pretty while it's here for a bit though.
We’ve only had a dusting so far. I expect it will stay until March or so.
I can’t wait to move away.
  • USA Proud
Reactions: RINC
The South Eastern part is my favorite. I do like the Flagstaff area though. We're thinking of visiting the Flagstaff area eventually ourselves.
Reactions: DB04RedJeep
Worked on the Jeep most of the day and went mostly sideways.
The double din install keeps hitting speedbumps. I had to cut down a couple uclips to fit the dash.
I have not installed the shift bezel or handle after the console repaint. It makes it a real pain to shift. I got a bulb for the shifter today and when I went to install it, the housing broke. I superglued the housing back together and cut a strip of material and super glued it to the housing.
The HVAC wiring keeps falling off, so tomorrow that's another project.
man whats the issue with installing the double din ? thats so easy a caveman could do it !
Damn it. I already took a shower, but I've got the itch to go work on the Jeep.
Git R Done
day guy GIF
Several issues.
I'm a perfectionist.
I bought a 25 year old Jeep. Everything the PO's tried to fix, they did half-ass or not at all. When I start working on one thing, I end up working on two or three things.
You know how things snowball. I pulled the seats to run a tap down a couple of the mounting holes. I didn't feel safe with the seats moving all over the place. Each seat only had two bolts and neither of them were correct. Since the seats were out, may as well pull the console, clean under it and paint it. There was overspray on it and the shift light was out. I pulled 14 coins, 3 pens, a bunch of toothpicks, a baby sock and about a 1/4" of muck off the top of the hump. The console only had one screw holding it in. The seats and console are out, so may as well put down the Kilmat and install the flooring. Meanwhile, figure out what bulb I need in the fog light switch since the radio bezel is off, screw around with the wiring on the HVAC, run the backup cam wiring, wire in a power port under the dash for the USB plug and phone charger. Get rid of the extra wiring behind the dash that isn't connected to anything. I also noticed most of the fuses were corroded and some of them were the wrong amperage. Replaced all of them.
So yeah, installing a radio is easy if that's all you are doing.
My last Jeep that wasn't new was almost 40 years ago. There is a learning curve.
On my 65 and 67 Mustang, I can rip through almost anything in a day, but I have owned vintage Mustangs since I was a kid.
