5632
There are many request what changes in temp were experienced. How do you measure under hood temp?
What was the difference in degrees?
I don't know about the engine bay temps, but I do know that adding hood louvers decreased the intake temps about 10 degrees. This suggests that the intake plumbing that is exposed to the engine bay is not being heated as much when heat is able to escape through the hood.
Before my vents I needed gloves to open up the hood to use my onboard air.
With them, I don’t need gloves but it’s still pretty warm.
Engine seems to operate the same.
Before the cowl intake, I could cook food in the engine bay. After the cowl intake, a burrito takes a long time to barely warm up after leaving the gas station.
What change in engine bay temps would mean something? By which I mean it would improve performance or longevity in some meaningful/measurable way?
Heat degrades plastic and many other materials over time. Reducing heat exposure will help things to survive longer.
If the tradeoff is between being able to heat my trail lunch on the fuel rail or reducing intake air temp by ten degrees Ill go with a hot lunch every time.Before the cowl intake, I could cook food in the engine bay. After the cowl intake, a burrito takes a long time to barely warm up after leaving the gas station.
I thought of that, but how much longer with a 10* difference? What? 6 months? 5 years? 20 years? Who has any hard data? Seems like too many environmental factors (live in AZ vs MN, etc...)
How much more space proportionally does one have for heat release when they install some PS hood vents? GCherokee hood vents? Or God forbid but MotoBilt Fab 4 Wanna Be hood vents? I mean we're driving down the road and air is moving in and out of the engine bay (I assume). Water gets up in there so air must be going in there.
Not burning my hand on the prop rod would be nice. I've never owned a vehicle that reaches the APPARENT high temps the TJ does.
I'd like to put in some hood vents, but what with all the rain we get here, I'd like to put them in the side of the hood. Maybe Buick port holes or something.
When I see non-factory louvers on a vehicle, I check the rear for a wing.
First, make sure the cooling system is operating properly.
Running a colder thermostat on a hot day does not make a bit of difference. It does make a huge difference on a cooler day. Your engine may not reach the proper operating temperature to burn off crankcase moisture.
Remove the cowl gasket during hot weather months. If rain is forecasted, it's a couple minutes to replace. If the hood bounces, buy a cheap replacement cowl gasket and cut 3 pieces about six inches long and space them out.
If underhood temps were an issue, sometime in the last 75 years, Jeep would have come up with a solution.
