Edit- Can't afford Jezza's Turbo kit yet so nitrous will do![]()
can't afford: Jezza's turbo kit
can afford: blowing up stroker with a 300hp shot of nitrous
New motor mounts, tie rod / drag link XJ upgrade. Now to the alignment shop
Or you over pressure the manifold so your floor plan bolts back out allowing it to fall out as you shift into 17th gear.
It's all fun till you kick the Rods out the side of the block !![]()
Aye....prioritiescan't afford: Jezza's turbo kit
I just purchased my 2nd set about 500 miles ago. All of what you said plus killer off road!!
Uh oh....
Went to Summit racing saw a Kc pod light,went to checkout and let's just say the bottle flew over to my passenger seat.....
So qnyways yeah the jeep is now getting nitrous,I'll probably just do a 75-100 wet shot.
Do I need this for my daily Lj? No. But will I use nitrous daily ? No.
Does it need it ? YES....YES IT DO CAUSE ME WANT IT
Once I build my new stroker motor and get a tranny I'll most likely dump a 300 shot until it or the tranny blows......
On the upside, you won't have to worry about disassembling the front end of your TJ again, it'll take care of itself...
Replaced the Heater Core and snapped a frame bolt while cutting off the factory rear shock body mount bolts. Snapped two front swaybar bolts also.
Uh oh....
Paint it red and attach it to the rear roll cage …. If anyone asks it’s a big fire extinguisher![]()
I was thinking about that and slapping a powertank sticker
Powdercoat it that candy like red and I'm set,I got a 15 pound powertank as reference too![]()
Is it really?tie rod / drag link XJ upgrade.
My LJ handled great in snow and slush. Maybe check your DOT code on your tires. They don't wear down but can get very hard and slippery.
