I know that they are old and need to be replaced. It is on the list to be done this year, but it is almost $1.5-2k for 5 new tires. I need to budget for that.
@97JadeTJ where did you buy the tires online? I usually get tires with Discount Tire since they do free rotations and stuff like that. I also go with 5 tires instead of 4.
But what you were describing about your old tires are exactly what I am feeling too. My tires right now are from 2014 or 2015.
I don't know if it is the tires (BFGoodrich All-Terrain KO), the age of the tires, the nature of 2WD/4WD vs AWD, or just the conditions that were that slick, but I was driving around in snow last night and was slipping a decent amount. My AWD Outback with snow tires is extremely sure footed in these conditions. The Jeep was slipping a decent amount last night. I stopped at a light on a hill and was slipping when hitting the gas. Put it in 4HI and got it going. Had a couple of slight slips just driving straight down the road. Had to put it in 4HI again in the parking lot in the restaurant because once again I was slipping getting into a parking space.
I'm still learning how this TJ handles in winter conditions.
When i repainted my grill i used rustoleum rust remover,Its in a spray bottle but comes out as a gel
Worked great for me especially since i had 50+ rock chips with rust wanting to form
Another tip is to sand the rust spot a little bit and then put that rust remover to help it do its thing. Also ! im sure Theres a bit of that rust is under the paint where its peeling too so be aware !
After removing the rust get some etching primer,(kinda optional) Filler primer and sealing primer and for the good stuff the Paint and clear but for something so small i wouldn't trip about using sealing primer on it,But thats just me!'
Edit- as far as the dent goes i wouln't know what to tell ya,other than a stud welder to pull it out and work it........or just fill it with body filler....i wouldn't do that though
Thanks for the tips.
I'm thinking about taping it off and taking a Dremel to the area to remove the rust and a bit of paint around the rust spot. Then, I'll use the rust remover like you said, prime it, and then use some touch up paint on it. I'm not worried about the dent too much. Also, this spot is the worst body spot on the entire Jeep.
I'm wanting to wrap my grille soon. I'll use the rust remover on the rock chips on the front of it before I wrap it.
I'll be on the lookout for a decent CAI setup now !
Brother there is no way possible you lost 20 hp going back to the stock set up.
How dare you doubt his butt dyno readings while doing burnouts on drive pavement.![]()
I finally saw this LJ that's been for sale locally. The expensive top might look better if the Jeep was lifted on 35s.
Welp I now installed my new battery cage,it's from Next Venture motorsports
This thing is rock solid and my battery ain't moving any time soon to say the least. Oh and I also got a new odyssey battery too a couple weeks ago when It was freezing here in Texas because my Previous Ac Delco bat. Wasn't cuttin it!
My only gripe is that the nutserts suck,all of them! They fell out the second I tried to bolt the hold down pissed me off more than anything but oh well, But other than that it's a great kit! well made.....simple design and because it matters its MADE IN MURRICAH BABEH
edit- Put the stock airbox back on instead of running a pod filter cause of the rain ......The thing lost like 20 hp if feels like,it wont peel out on dry concrete no more like it did with just a pod filter with a prefilter (which someone stole from my driveway cause no hood).....but this looks more formal for the meantime rather than the stock tube being ziptied back with a pod filter on it
