Spent some time in the garage this afternoon playing with my Pinion angles.
Ended up adjusting 8 turns out on my Rear Lower Control Arms, so that I could actually utilize my Rear Uppers
(yesterday the Uppers were maxxed as short as they could go)
Here's a photo of my rear pinion angle. Roughly 6.5 degrees.
As well as my rear Transfer Case angle, measured from two spots, at 5.6 degrees.
Rear Pinion/Transfer Case angles SEEM to be correct.
(although I'm learning what I'm doing, so I could be botching something completely...)
Also adjusted the front to what I THINK is correct...
5.7 degrees on the front pinion
Followed by 6.7 Degrees at the front Driveshaft.
Ultimately, I fixed NOTHING.
The vibrations are STILL there at 65mph, and got no better/worse.
They're the same as they were.
At this point, i'm just uber confused.
With the LJ having the longer rear shaft, I wouldn't think I should be having issues, given the angles of everything.
Nothing is at an "extreme" angle.
I'm thinking it's time I take this entire conversation to a thread of it's own, and let the big-boys duke it out with solutions/theories.
I'm planning to go to Lowes tomorrow, to pick up some washers, just to see if that possibly can cure some issue.
Just not sure where to start, am I putting washers between frame/skid to lower the TCase, or am I putting them between Tcase and skid to raise the TCase?
Any further insight is appreciated!
Your front and rear angles are reversed. Typically the rear pinion is 1* lower than the driveshaft and the front pinion is 1* higher than the driveshaft.
Lower the rear pinion to 1* lower than the shaft. Check for vibes. Raise the front pinion 1* above the shaft. Check for vibes. Remove the front shaft. Check for vibes.
