If there is one bad aesthetic on a TJ it is the signals in the fenders-I did white lenses on white to minimize mine.
Likely intentional since they went back into the grille on the JK.I agree with you. But I did smoke lenses (with amber bulbs) on black to minimize mine. Does anyone know if this location was intentional for the design of the TJ, or was it some sort of government mandate?
That’s true, I don’t love the look of the location on the JK. I put mine closer together and I think it looks better, but maybe I’m illegal.Except the grille is W I D ER on a JK, and the turn signals are at the very outside edge of the grille. The turn signals are not even centered under the headlights on the JK; they are way off to the side, which looks odd to me.
I wonder if the turn signals were under the headlights on a TJ, they would be too close together for some stupid regulation?
I know I love the lights and the fenders,would like to know more about this jeepThat looks perfect. The proportions are right on. It looks like it came from the factory that way. This is exactly how I would like mine to look.
I think the chrome bezels made the difference, as it is consistent with the chrome headlight bezels. Do you where the chrome bezels came from?
I believe I used 55077885 and 55077884 which is the p/n from the 2007 Mopar parts guide. I can't say your numbers are wrong though.Are these the correct part numbers for the Jk lights used to move signals to the TJ grill ?
Part Number=68200290AA & 68200291AA
ThanksClear vs amber.
Makes sense. I'm in favor of the more traditional amber turn signal look for a Wrangler.Clear vs amber.
It's easily done with nothing more than a 3 1/8" steel hole saw and a pair of JK turn signal enclosures, I did mine years ago. JK front turn signal enclosures fit the 3 1/8" hole perfectly. The TJ's front turn signal bulb enclosures fit the JK turn signal enclosures perfectly.
If you get serious and are ready to do this, I have a few additional tidbits to make the mounting of the JK enclosures easy so they don't require anything additional to old them in place. The enclosures can be made to twist-lock into place with no extra hardware required.
Edited to add another photo of the large 3 1/8" hole to show the notches cut into it for the ribs on the bulb enclosure to fit into.
Yes, to match the 3 ridges on the turn signal enclosure.I can't tell in the photo, but there are 3 notches?
Thanks! Brian
These photos are from my previous TJ but I did the same thing on my current TJ.
I made the hole and enclosures so they twist-lock into place.Hi. I'm doing the same to my TJ. How did you mount the JK turn signal to the fender? Thanks for the help.
