Mig or Tig ? hahaYou gotta weld those! Don't you know anything?![]()
Acetylene only … it's full of oxygen. lolMig or Tig ? haha
I’m running into an issue where the tib seat slides are hitting my seatbelt roll. Do you happen to remember how you got around this?Stock seats break my ass. I looked for options for a while and finally settled on seats from a Hyundai Tiburon. They are very comfortable, supportive and have adjustable height and lumbar support. It was easy to make some quick brackets for the Jeeps seat tracks. There are some other good aftermarket seats but I didn't want to spend a lot of money. My total cost was around $175.
Plus they look really good.
I had the same issue. I had to cut a notch in the seat rail to clear the seat belt mechanism on the passengers side. The drivers side has a different mechanism and didn't require any extra clearance. It did take a little trail and error to find the sweet spot. Unfortunately the mechanisms are not interchangeable. The other option is a set of seat risers. I put a set I had lying around in but it felt a little high for me.I’m running into an issue where the tib seat slides are hitting my seatbelt roll. Do you happen to remember how you got around this?
I’ve actually already begun the same thing. The op messaged back pretty quickly but I’d already begun brainstormingI had the same issue. I had to cut a notch in the seat rail to clear the seat belt mechanism on the passengers side. The drivers side has a different mechanism and didn't require any extra clearance. It did take a little trail and error to find the sweet spot. Unfortunately the mechanisms are not interchangeable. The other option is a set of seat risers. I put a set I had lying around in but it felt a little high for me.
You will also need to cut off some of the plastic cover on the inside of the tiburon seats to clear the center console. Once bolted in you'll never notice.
I took a look at look @PC06 update to the original thread. I like the solution they came up with. I guess I'm just to quick to look for an excuse to use a power tool.I’ve actually already begun the same thing. The op messaged back pretty quickly but I’d already begun brainstorming![]()
How do I know if I have C rated tires?If you have C rates tires, set your air pressure to 26 psi. It will soften the ride.
I installed seat heaters in mine. I also have some back arthritis in my back and the heat feels good on it. I will say though that with the soft top the heated seats don’t get used in the jeep during the summer as much as they do in our car. We blast the a/c in the car with the heated seats on and it great.
https://wranglertjforum.com/threads/how-to-install-heated-seats-in-your-jeep-wrangler-tj.15326/
I have a 2000 Sahara that I love to drive. Problem is I’m 51 years old ( I know that’s not old for a lot of you ) but I have arthritis in my back and the interior and the seats just aren’t comfortable for riding for a long time. I know a lot of y’all will think just suck it up and drive. But if anyone has any suggestions or have done anything to help their Jeep be more comfortable. By the way I just had 4 Rancho shocks installed.
Get some BMW E92 or E90 seats and install them![]()
https://wranglertjforum.com/threads/bmw-sport-seat-install-in-jeep-wrangler-tj.31189/
Thats what Im doin after seeing another members success. Theyre far more comfortable then 20 year old Jeep seats. I greatly dislike aftermarket seats as they are subgrade Vs factory seats, esp luxury factory seats
I just picked up a pair of powered and heated E90 seats for $100 in pristine condition locally off FB marketplace from a kid that upgraded to the SPORT seats. I may decide to go with the SPORT seats also but couldnt find any locally so Im trying these first
I will need to figure out what circuits and location to supply power to use them but should not be too hard
Nothing more comfy than heated, power, leather WJ seats. I used to fall asleep while driving when I had them. Now I do that in my Tesla.
Wow, those are like a mile off the floor.
