I guess in a perfect world everyone would carry a rope sized to their vehicle for recovering others.
In reality I'm the only one with equipment or first aid gear or warm clothing.
We did too but we pulled and at most gave it a bump.I grew up recovering with log chains so I look forward to seeing what others with some experience have to say about it.
I've made this point many times, one of these days it will stick, I hope. Every recovery bag within easy reach should have a roll of cheap electrical tape. If you toss a loop over a hook without a keeper, tape it in place with several wraps and cut the tape when you are done. The easy reach part is if the bag is in the back and hard to get to, put that roll of tape beside the seat on the floor with your gloves and a shackle or two.In one video I learned a neat trick for those with open ended hooks, he uses the Velcro strap that the rope stores in to secure it to the hook.
I still carry a Peerless CC2003 2x30 strap.
I've got a 2x20 and 3x30 strap ..and 4 x 8 tree savers. Mostly use them for winch extensions, bridals and flat towing.
I find broken straps everywhere...sides, middle of trails, roads, tied around trees, bumpers, axles.
Burned cars we recovered (on my YT now) were dragged and flipped with 1" rachet straps. Of note in that video we actually pulled apart several factory shipping points...so if you really want to see how flimsy those points are watch away.
I also find them tied together which is hilarious because the knots they use usually 1/4 the load rating.
But hey...in all those broken remnants we hardly find any vehicles...so it did work enough to get someone out...but who knows what got broken.
Cheap gear can be really expensive.
And don't get me started on recovering a Toyota several years ago when I too didn't have much gear. Told the guy he didn't have any recovery points and that we were going to do damage pulling...creased a fender as predicted but saved the guy, his buddy and girlfriend who were all in jeans and t shirts...snow pouring down...from spending the night in their truck. So then the asshole asked me for my insurance...we all.learn lessons the hard way.
Yep chains and wire ropes here. Later we went to two and three inch nylon straps. I still carry a Peerless CC2003 2x30 strap. It’s rated breaking strength is around 15000lbs which is less than most 3/4 inch kinetic rope. We just make do and not try and break it. I have no need to change it out currently since the majority of trails up here do not give you much opportunity to use a strap.
Times when I would get stuck on a pipeline right of way, there was always a nylon sling to get me out. *I think sling was the term they used* They never used chains.
Excessive is very subjective. If the same force were applied to a properly sized kinetic rope with a bow shackle in the bumper tab, would it still have failed?
This example does show a possible new product opportunity: shock-absorbing fuseable link to limit overloading in a controlled fashion. Basically an upsized shock absorbing lanyard like that used for industrial fall protection: folded webbing stitched together where the stitches rip when overloaded, letting the webbing extend. This would make the Bubba-ropes a bit more Bubba-resistant.
Just a question not related to yanking someone out, but using a tow strap to get someone form being high centered, out of a hole or an obstacle. I was told that its better to connect to the rear of the pulling jeep than is to connect to the front of the pulling jeep, and putting it in reverse to free the stuck vehicle is this true or a wives tale
I've never seen the pulling damage anything pulling from the rear. I have seen several break front axle shafts, u-joints, and damage ring gears pulling from the front.
So we would use the electrical tape around the rope making the loop smaller so it is less likely to slip off?
