Inexpensive (El-cheapo) TJ Mods
This is brilliant!! Only one question, when it's dark and your looking under the hood, do the light blind u?
Reactions: Kiwi TJ and Chris
Thanks guys! It's not too bright because I don't stare at the light. Lol
Here's my first mod and first el cheapo mod... Roll bar flashlight holder by Bartact.
Smittybilt and E-Autogrilles also make one similar but they didn't look as strong as this one. I have a ridiculously large 6 D cell Maglite that I've kept in my truck for years(it was free from T/A Truck Stops with fuel points) and wanted an elegant way to store it in my jeep.
$20 on Amazon
Bartact Roll Bar D Cell Mag Flashlight Holder - Black https://www.amazon.com/dp/B01A9NR7F8/?tag=wranglerorg-20
Reactions: JP13 and Chris
I noticed when I got my tj there was small bulbs in the headlights that weren’t wired up to anything. I did a quick power and ground check to see if they work sure enough they did so I ran my own wire and wiring loom and made DRLs out of them they come on and off with the ignition. You can kinda see the glow in the drivers side headlight in this picture. I’ve since upgraded my headlight bulbs to LEDs so the DRL lights are next if I can find bulbs. Not all TJs have this option as far as my research provided it’s a mandatory Canadian assembly but the Jeep was built in the US so I’m not sure how they ended up in this jeep. But I’m not complaining!
Third light mod, 5 bucks...
Daystar dash pod. Last year in Idaho we kept throwing our radios on the dash and it finally broke the defrost grill. Adds more usable storage for 21 bucks. I plastidipped the entire thing to keep rattles down...
What did you use to replace your defrost grill. Mine is shot.
Reactions: Blank
Searched, but didn't find a thread...has anyone done this mod? ac on/off switch:
Being in NM it might not be an issue, but if you lived in a wetter climate, you really want your A/C to run with your defrost. The A/C is really a dehumidifier, and will defrost your windows quicker and keep them dry. If you take that away they may take longer to get rid of the water which fogs the windows. It does look high tech though!
It is not an issue here. Most cars and trucks have the push button AC actuator, with the AC cycling on with the defrost settings. I am more interested in using the first three settings for heat in the winter without the AC compressor cycling on. I know when I want AC. The writeup above seems to simply interrupt the light green wire, which is a ground when the AC setting is selected.
Reactions: Squatch
I figured that is what you were doing. I just wanted to make sure you knew the a/c is a dehumidifier is all. Carry on sir!
Even better than El Cheapo.....sell your useless CAI on Craig's list, and get a used stock air box and ac Delco filter. I got 150.00 for the Volant CAI that was on my Jeep when I bought it, and found a used stocker for 35.00. That and the filter element, and I ended up 100.00 ahead, anf no longer have rocks getting into the motor. Life is good.
