Swapped out the transfer case indicator switch while the belly pan was off.
Installed the Savvy transfer case shifter cable that's been setting in the garage since April. FYI, this is not easy by yourself.
Got the UCF belly pan installed and the RC brackets drilled in. I had to notch the belly pan to clear the front driveshaft and the driver rear RC brackets.
If I could reorder the belly pan, I would get the middle rise one. With the RC bracket, I only gain about 1.25" instead of the full 2. I didn't weigh it before, but it is at least 1/3 the weight of the stock one.
Tomorrow the front and rear control arm brackets will be cut off and the long arms installed. The rear would be done already but the VFD had 3 medical runs this evening and now the NASCAR race is on.
Pm if you used the lopro mount and got vibes.
