I'm late to the party
The hose is not a fix it's a band-aid. The fix is to drop the tank and sand down the "nubs" on the plunger in the valve.
It's blind and intimidating but go for it - you'll get it off. That's the hardest part of this effort
You are so right about that.
I was terrified that I was going to break something. Blaine encouraged me, and sure enough, it came right off.
fuel pump
Bosch for your 2005. It's what Mopar used for OEM.
Hey all, I did the GM hose fix a few years ago, and now having the same issue with this one. Has anyone encountered another more permanent fix for this, and also perhaps a temporary when you’re in a pinch and just need to fill up until you can get around to another replacement?
Cheers.
Cheers.
The GM hose is a band-aid, not a fix.Hey all, I did the GM hose fix a few years ago, and now having the same issue with this one. Has anyone encountered another more permanent fix for this, and also perhaps a temporary when you’re in a pinch and just need to fill up until you can get around to another replacement?
Cheers.
Go up and read the very first post in this thread.
FOR ANY FUTURE READER:
It's a grab and apply soft but strong pressure within the tank to get off the fixture the plunger is within. It's blind and intimidating but go for it - you'll get it off. That's the hardest part of this effort to fix an issue that will damage your paint, flares, etc.
Took me about 3 tries to muster the courage that I wasn't going to break it.
Reviving an old thread. Anyone know where I can get this GM 15131046 flapper hose?? Everywhere I look says "out of stock."
Thanks in advance!
Thanks in advance!
