Oh I like those fenders ! Lookin good!She still isn't pretty yet. But she's on her way there.
View attachment 39581 View attachment 39582 View attachment 39583 View attachment 39584 View attachment 39585 View attachment 39580
Check my build thread...rust experience in spades. POR is good stuff, gotta prep properly though. I've only run into one seized control arm bolt...every other one I've tried getting out or loosened up has freed up, eventually, for me.Didn't realize just how bad the surface rust was until I removed the tire roughly 5 minutes ago. That being said, the bolts have been cooperating so far, unlike the control arms which took 8 hours to remove. I had to torch every single one out, minus the rear ones (obviously directly beside the gas tank)
Anyone else live in an area/used to live in an area where they use salt to counter winter? Talk about brutal.
I'm assuming por 15 will cover this up no problem? Anyone with experience able to chip in their 2 cents?
Nice job !
Do you have to buy new flares if you go with the smaller or is there a way to make those smaller? Will they allow you to return them after you installed them?
