Adapter came in for transfer case. Test fit to make sure everything will work and I have enough fasteners to hold together to test fit it in LJ. Ordered most of the fasteners I need for when everything is done.
I also degreased the transfer case. I need to degrease my LJ case too and tear apart.
Weekend plan:
-Cut factory motor mounts and tack weld in Holley mounts
-Rebuild transfer case, Chevy front, LJ rear case
-Test fit engine/trans/transfer case/ LS3 manifolds
I have to get the 4L60E to builder next week as it is a 4 week lead time (unfortunately from when you drop the transmission off). I was pretty concerned with this but the reality is I have a ton of other work that there is almost no way it will all be done before the transmission is.
I’ve looked inside this 5.3 but never got as far as mic’ing bores or checking bearings. Hoping to just rering and reseal this engine. Determining this is an immediate next step after transmission is sent out.
