Hello everyone, I am currently in the process of Re-Gearing and installing an ARB Air Locker into my Jeep TJ Dana 44 Rear Axle. After a few months of watching BFH Garage videos and doing my own research I now felt ready to tackle the project. I was hoping I could get some feedback on the below specs and images to make me a bit more confident in my work, or catch a mistake before it's too late.
I usually do a write-up after completing a big project for people to learn from, but for this I figured it may be best to start during the project so more people can learn the entire process while I figure it out as well.
Axle / Vehicle:
- 2006 Jeep Wrangler Sport
- Dana 44 (Non Rubicon) Rear Axle
- 4.10 Yukon Gears
- ARB Air Locker
Backlash: Currently reading .008"
Left Side Shims: OE Master Shim, ARB Master Shim, ARB Seal Housing, .0230 Shim Pack (.005 + .005 + .010 + .003)
Right SIde Shims: OE Master Shim, ARB Master Shim, No Shim Pack.
Carrier Preload:
Set so the carrier needs to be installed with 6-8 good whacks of a dead blow.
Pinion Preload:
Not at this point yet.
OEM Pinion Depth: .0545"
Current Pinion Depth: .040"
.0100 Shim Pack behind inner race + .030 Oil Slinger behind Inner Bearing
(.008 + .001 + .001) + (.030) = (.0400)
Gear Wear Patterns:
(I have already been told these are not the greatest pictures, and I will be working on getting better ones today that show more of the face of the tooth).
My main questions are...
1. Does the gear wear pattern look acceptable?
2. Is it okay that I have no shim pack on the right side of the carrier?
3. Pinion Depth seems far, is .040" a normal number to be reading?
4. Any other lesser known pointers that I should know?
I wanted to get this posted here now to begin the discussion, but I will be working on this today more. I plan to get better pictures of the wear pattern and check my measurements on shim thickness sizes. Also I found this link last night that seems to outline a really good way to get to a starting point, I will probably save the above measurements in case feedback is good, but also play with some new ones to see if I can get better wear / numbers. Any advice on this is super appreciated and I look forward to discussing!
Axle / Vehicle:
- 4.10 Yukon Gears
- ARB Air Locker
Carrier Preload:
Pinion Preload:
Gear Wear Patterns:
