A ball-end carbide in a die grinder is the ticket:
I’m working on 16g sheet metal and getting what I think is a good continuous arc and superficialmetal deposition, but not enough penetration. How should I adjust the settings?
The right side is the so-called bead, the left shows the lack of penetration after I ground it flush.
Or maybe it’s a bad ground? The clamp is a bit mangled although I ground it down to shiny metal.
I'm no expert but I wouldn't try to run a bead on sheet metal. Have the welder high enough so you can make quick tack welds with full penetration and jump around. Going slow enough to keep the piece cool if warping matters
How many seconds ballpark is a ‘tack’ in a case like this? 0.5? 1? Less than three?
Hey by any chance could you help me with my engine mount welds ?
I've been trying to practice for my engine mounts i planned on welding in. I bought a lincolm 210mp and well flat and horizontal doesn't seem to be an issue but vertical is kicking my butt. I recently tried the upwards triangular motion with a better result but I'm still trying to figure out the welder without burning a whole threw my frame. I'm welding 1/4in steel (holley engine mounts 3/16 steel (tj frame ears) thank you!
They key to learning to weld is only changing 1 variable at a time.
I’m experimenting with my used Lincoln WeldPak100 and trying to learn what a satisfactory weld looks like, and if my welder is even functioning properly.
I did this with a couple coupons, approx 14g to ~11g steel. I’m sure the bead is terrible and I’ll work on that, but what do the patterns on the other sides mean re: penetration and strength?
I’m wondering if this is basically correct, or if i have something wrong with the setup, like a bad ground clamp/connection, too much/too little gas, wrong wire, etc. View attachment 619057
Your bead doesn't look bad & there's not a lot of spatter which is good. Whenever I'm inspecting welds I always manually wire brush to get rid of any loose debris & use a flashlight from multiple angles.
Those patterns on the back is just the heat affected zone (HAZ) basically where the base metal got hot. They can be used as an indicator of what the weld is doing, but it's mostly inaccurate information.
Edit: If you want to see if you are getting enough penetration on a fillet weld like that do this break test.
Or this for a groove weld
Dealing with porosity and could use help.
1/8" material
Clean grounds
Clean welding surface (flap disc'd)
Wire speed 285
19 v
Gas on, flow at 14, no leaks
Problem is I am experiencing a lot of porosity. These are short, small welds but anything longer is just as bad.
Thoughts?
