@JMT the cat is out of the bag now...
Any luck on the vibrations? Are you sticking with the 37's for now or?
The transfer case was hard into a bolt on the savvy crossmember and it almost put a hole in the transfer case. I corrected that so I don’t get those vibrations.
The oil pan skid was hard against the transmission pan and I corrected that so I’m not getting those vibrations.
The transmission cooling lines were against the tub, and I moved them away and so I’m not getting any vibrations from there. I still have more to check in terms of things touching, but I corrected the rear pinion and got up to 77 miles an hour with only the rear driveshaft in and did not have any driveline vibrations
