So, it seems I will need to create a lot of backlash.
I think i forgot to tighten the bearing caps all the way on the first setup. I have now moved over 0.030 from the passenger side to the driver's side, and when tightening the bearing caps backlash goes to 0 and its hard to even turn the pinion.
@hosejockey61 - is there a limit on how much shim i can have on a side? Going to have to drop down to a stack of thin shims on the drivers side as im now below 0.100" of shim on the driver's side and still 0 backlash.
