Except for their ability to send decals with the orders.![]()
Maybe Jerry still has some
Their website states up to 1" clearance gains depending on the year Jeep.![]()
I used the tuck so I wouldn’t have to run a huge suspension lift have 3 inch teraflex springs.all of this to only clear 35 inch tires,I thought tires are the only way to add ground clearance?
My main goal, which should be done by March is to put a 3.5" Core Camp Series kit on my 06 Rubicon. In the meantime, I have been going down the tummy tuck rabbit hole, and was thinking about getting that first. I was looking at the Barnes4x4 and Teraflex flat bottoms (if there are better, I would love to see them)
What I am planning is the new belly pan, 1"MML, relocation of air, and a Woods DC Ds. I guess my biggest questions would be: Will the ds work before lift, it states for lifts 2"-6", but being DC I assume that is "should" be ok? And also, will a Body lift be needed? I have read mixed things, but knoing the large Tcase in the Rubicon and the air system...
Or am I just backwards and should tackle the lift first?
Thanks all!
Not sure if it’s better or not, because I’m uninterested in picking some type of argument. But you asked if there are better options, and in my "OPINION" there is:
I’m a pretty big fan of the Savvy skid upgrade and put the engine skid on as well.
Couple pics, I have 4” Currie springs and Savvy CAs, I had to put a 1.25" BL and MML both from Savvy as well, although I should have gotten the MORE Bomb Proof MM's and 1" lift. Actually, now that I think about it, the grill snubber for the body lift, Blaine sent ones from his BL kit that were better, ha. I'd get the Black Magic BL if I was doing it now, but I bought mine and had it sitting for a year or two before install.
I got a TW DC driveshaft, but mine doesn’t have Rubicon TC, just Rubicon axles.
I thought Texas had red mud too. Are you an @Irun inspired Jeep cleaner? If so, I'm jealous. Looks great!![]()
HA, that was right after install, and I put in Rubicon axles, It was all open, so I flap wheeled anywhere there was rust on the surface (Texas Jeep TJ) so not a lot, and hit it all with Krylon Semi Flat.
I grew up in Houston, which is 100% the Bayou City, rode dirt bikes and then Jeeps in DEEP mud. Loved it, now...booo, mud and red East Texas dirt sucks. I'm in Central Texas, and avoid it ha.
I'm getting a CJ5 up and going again, driveline issues galore, but here's the Transmission and TC, and yes, caked in East Texas red freaking clay/dirt/oil/grease mix. It's even under seal covers and caked in like a motha!
I'd rather drive in the rocks in the hill country and just wash off the dust....scraping caked on crap is getting old, ha.
View attachment 647595View attachment 647596View attachment 647597
I installed the non-MML MORE Bombproof mounts - rubber bushing style ones - and have some reservations about them. I bought the OMIX set first and I'm pretty sure they were cast from vulcanized dogshit. So naturally I went for the other end of the spectrum and got the MORE with the rubber mount bushing. And the MORE Bombproof are as advertised extremely well made and stout.although I should have gotten the MORE Bomb Proof MM's and 1" lift.
I'm pretty sure if you go with one of those UCF LoPro mounts you can avoid the body lift. However, I don't know why anyone in their right mind would want to do that.
Just starting to look into this stuff and a little confused… Why wouldn’t someone want to use a lopro mount? Wouldn’t this help avoid vibes by keeping the drivetrain in better alignment?
The LoPro mount is known to be accompanied by more vibes at idle rpm’s because there is less vibration damping through that transmission mount.
