I am planning on doing the same setup for my 2005 X RME. BDS 2”, 15x8 wheels -22 offset, and 32x11.5xR15 A/T tires. Will also do the steering stabilizer and JKS links. This should be good for on-road performance and mild off-road performance, but won’t have enough clearance for more serious off-reading. Front wheel clearance should be about the same as stock if your wheels have a decent offset to compensate for the wider tires. I have the 3.73 Dana 44 rear axle and I don’t want to run bigger than 32’s so I can keep my on-road acceleration and fuel econmony reasonable. I’m like you...going to the 3” lift gets much more expensive and can start to get a little more risky with the change in geometry. I just want to empty one pocket, not every pocket! LOL. I also want to swap my DP/cats and install a cat-back to replace the original exhaust, so I need to keep some $ freed up for that. My original goal was to buy/build a rust-free TJ running the 2” lift and 32’s for about 15k. I’ll probably be at 16-17k by the time I am done though. I’m calling my build OEM+. Here is an example of how it will look:
https://www.divtrk.com/yj-59
