My radiator fan in my 99 4.0 is knocking the fan shroud at the 6 o’clock position when started in cold weather (~20° or below). The knocking stops once the vehicle is warmed up. I can manually stop it by barely pushing down on the shroud to give the fan clearance. It also appears that my coolant reservoir is pushing against my power steering pulley at times. The pulley has rubbed a hole into the reservoir. It’s not touching all of the time.
I have no idea how long the reservoir has been making intermittent contact with the pulley. The problem with the fan hitting the shroud is new, and it only does this in the cold and until warmed up. I can’t make sense of the scenario.
I haven’t made any recent changes to the Jeep.
