Yes, looks good. I tried to take the pics where you could see the pad. Not the best pics!Rotors ok, got plenty of pad?
I don't see how the type of rear brake will affect hill climbing. The parking brake performance will actually be less than the rear drum. On the disc setup, the parking brake is inside that small top hat section in the middle of the disc. It has much less surface area, which is a key variable when it comes to brakes performance. More surface area equals greater stopping force, all else equal.Is it true that e-brake performance and climbing hill performance might be enhanced? I read that in the other thread on disc brake conversion, but didn’t know if the info was accurate.
If disc brakes are worse than drum brakes, why does anybody want them?
That will look sharp! Love the attention to detail painting bolt headsStarted painting the Dana 44. Got to the Diff Cover, bolts and Rotors today, inside and out. Cling wrap has many uses, one of which is quickly masking off areas, cutting to fit and easy removal.
Geez, it looks like I messed up my thread. I had a post with a pic of my new free trailer. I'll fix it. Thanks!What's up with the trailer picture?
Yeah, friend who owns the Lakehouse at Buchanan used it to transport his kayaks and fishing gear. Now that he has the Lakehouse he doesn't need it anymore. He's moving too, so he's trying to get rid of stuff. Fun find. Hopefully I can find a short axle that will work for it. I think this one will work.Ah, thought something wasn't adding up there. So you picked up that trailer for free?
That is very good to know. I bet I could find one around our parts. Jetski's are a dime a dozen...And it's even the right color! Bonus! FYI, jetski trailers have the same lug pattern if you happen to find a junk one and can use the axle and leaf springs from.
