They dont look bad, i dont feel any looseness in thoseHow do the control arm bushings look?
Also check them for tightness
I'll give that a go. Does anyone have those numbers on hand ( or a link to them?)
This is the frame side correct?My FSM shows 55 ft/lbs for axle side and 65 ft/lbs for the frame side of the track bar.
Axle side was still correctly torquedYep, but wasn't thinking about the frame side being cotter pinned, been a long day. Usually see the problem at the axle side from what I've seen, though.
Should I go about removing the cotter pin?Axle side was still correctly torqued
You'd probably be fine to leave it for now. You might want to do the steering test again and pay special attention to the ball joint on the track-bar, looking for any excessive play. At least then you can likely rule that out.Should I go about removing the cotter pin?
Ugh man, theres no way I'm gonna be able to sleep tonight with this on my mind when my jeep is sick, I'm sick.You'd probably be fine to leave it for now. You might want to do the steering test again and pay special attention to the ball joint on the track-bar, looking for any excessive play. At least then you can likely rule that out.
Man, I'm with ya on that. I've probably got gray hairs already because of my Jeep.Ugh man, theres no way I'm gonna be able to sleep tonight with this on my mind when my jeep is sick, I'm sick.
I'd double check the tire pressures and get them in spec ASAP if you haven't already. Tire pressures that are too high can be "triggers" of DW. Stock 30" tires should have only 29 PSI (per OEM tire pressure sticker on inside of doorjamb on drivers side). If you have larger\wider tires, tire pressures should be taken down a bit further yet (27-28 PSI for 32" tires, 26-27 PSI for 33" tires etc.). This will help your ride tremendously if you happen to find you are running on much higher PSI numbers than expected. Best to start with the simple stuff.Stock size. I'm assuming 32-34 (I had it checked at discount tire to the factory setting)
Can I just replace the bushings or does the whole track bar need to go?Could be worn out bushings in the track bar then. I would replace and torque to spec. Keep in mind, clamping force is what holds it all. Do not overtighten as the bolt will snap, 65 ft/lbs on the frame side and 40 ft/lbs on the axle side
