Fitting a JK spare to a TJ tailgate mount?
Moab
TJ Expert
Bohol, Phillipines/El Segundo, California
I'm wondering if anyone else has run into this fitment issue. And what your solution was?
I'm trying to fit my JK spare (265/70r17) onto my tailgate mount. The installer of my rims and tires could not get it to fit. First because it's the wrong thread pattern. But also because I assume the tire is bigger and wider than the stock spare I had on there.
So I blindly bought another 2" spacer like I had used on the rest of my rims. Thinking that would fix my problem. At least the bolt pattern difference. But I fear that 2" spacer is to thick and will take the spare off of the rubber bumpers. And cause my tail gate hinges to wear badly.
I could measure. And maybe buy the correct adapter/spacer with the perfect width to keep the spare - riding on the rubber bumpers? If anyone has done this and knows the proper adapter/spacer that would work. That would save me alot of time.
I'm going to try to mount the 2" spacer this week. And see if I get lucky. But I'm pretty sure 2" is to much. Someone correct me if I'm wrong. Or if you have a more elegant solution. Please let me know.
I guess if there's to much space with the 2" adapter I could build up the rubber bumpers. Does anybody sell ready made thicker rubber bumpers for the tail gate? I'm not really set up at the moment to massage a pair of hockey pucks.
Reactions: Cornbread
I have a JK spare on my LJ. I used a 1 1/2" adapter for the spare mount. Instead of extra OEM bumpers, I used hocky pucks shaped on a belt sander. Wear a mask, there was a lot of rubber dust. For longer bolts, I went to Lowes. IIRC, the bolt is a common 5mm thread. If not 5mm, it was a 6mm.
If the tire diameter is too large and touches the bumper, Smittybilt makes an adapter that lifts up and out.
https://www.smittybilt.com/product/index/184.htm
I have a lightly used one I no longer need.
I have a JK spare on my TJ tailgate mount. I simply put another wheel adapter on the spare tire mount and it works perfectly.
Reactions: rubicube
Well this just got more complicated. My adapter/spacer isn't enough to clear the bumper with the spare tire. I think it's 1.5". But I don't think a 2" would clear it either. So I have to find a spacer mount that connects the JK bolt pattern to the TJ bolt pattern. With enough depth to clear the bumper on the bottom of the tire.
The only "one" adapter I can find is this. (It says it's for a JK but the part number cross referenced to other ebay listings and amazon show it works with the TJ and the JK bolt pattern. This one is $35 and the other listings are $45+.):
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=382630862956
It has good and bad reviews on Amazon. But I'm going to give it a shot. As it's the only one I can find.
So I have to add this adapter and add to my rubber stops on the tailgate. I found a set of rubber stops for $15 on ebay. SO $50 total to get my spare back on.
Any ideas for cheaply extending the third brake light up? I'm wondering if there's enough wire to add some spacers to it too?
GOt another link? I can't find a picture of that part number.
Mine are 17” JK wheels.
I just double checked my spacer and it's 1.25" - not 1.5". But it looks like maybe a 2" adapter might work. I don't know about 1.5". How close is your tire to the bumper? Do you remember the tire size on your spare? Mine is 255/70r15 IIRC.
I hate to keep buying spacers. I hate returning stuff. lol.
I have a 17x8 wheel with 5.25” backspacing and a 1.25” adapter, which means it’s technically got 4” of backspacing.
The tire size is 35X12.5R17, and it’s sitting about 3” away from my tailgate, which I make up for by extended length rubber bumps.
My tires are 255/75 17 (32"). With just a spacer, my tire hit the top of the OEM bumper. I bought the Smittybilt spacer/riser. My new bumper has a recess for a larger tire, so I went back to a simple spacer.
Chris or anyone else:
One last question. Once I get the tire mounted on the new extended mount. How much extra rubber on the rubber stops should I add to keep the tire secure on the tailgate? Like say if I mount the tire and it's an inch away from the rubber stops - should I add an additional .5" to the rubber stops with my extra rubber stops material? Or a .25"? I wanna make sure I can mount the wheel flush on the mount. (Rather than riding up on the threads.) And then have the rubber bumpers adding secure enough pressure. Without the wheel - not seating fully.
Make sense? I guess if I'm off a bit I could let some air out. But that kind of defeats the purpose of carrying a fully aired up spare. But then again maybe the difference between 50psi and the 26psi I normally run would make enough difference in mounting the spare correctly. I just want it to be a tight enough fit that it doesn't vibrate or bounce and mess up my tail gate hinges.
There is always trial and error. But I would prefer to get some guidance beforehand.
I guess I could also mount it at 26psi. And then if I have to use air to tighten it up I can.
Hey @Moab
I know this is old, but I just installed some 17" JK rims just like yours. What was your final solution?
Rubber hammers from Harbor Freight. Cut the heads off and cut down to fit. Theyre like 3 bucks each.
Gotcha, thanks. What'd you use for cutting? Sawzall? I could imagine it might go better with slower strokes and a hack saw?
