Are these the housings you are referring to Mr Bills?
https://www.quadratec.com/products/97009_6001.htm
The part # is the same and they look the same so they should be the same.
BTW - There should be a small rectangular paper label on the back of the lenses you are selling with the part number. They are most likely P/N 002395031.
There is some confusion on Amazon as to which is the correct TJ conversion kit because Amazon lists the conversion kit for 7" round headlamps as containing "165mm housings, which is only 6.5". However, several posters on various jeep forums have stated that the 165mm kit linked below is indeed the correct kit for TJ's. There is also Hella product literature on the Interweb indicating that the overall diameter of the 7" conversion housing is 178mm with the lighted area of the lens being 165mm. Therefore, I suspect that the kit on Amazon has the correct P/N 002395031 housings and Amazon's product description is the problem.
Someone else will need to verify that the Amazon kit linked below is the correct kit. I purchased a single E-Code H4 housing when I upgraded the lights on my '06 LJ because I only needed to replace one in the pair of E-Code housings I already had and have used in several jeeps beginning in the 1980's. The new and old housings had identical part numbers but were not perfect matches due to the considerable difference in age and exposure to the elements (something only I seemed to notice) so I ended up purchasing a second new housing to match the one I had just purchased. My good old housing is now on my parts shelf as a spare. Had I known at the beginning that I would be purchasing two housings I would have purchased the kit from the outset because it is less expensive than purchasing the housings individually.
7" Conversion Kit on Amazon:
https://www.amazon.com/dp/B001G72SKQ/?tag=wranglerorg-20
Amazon Link to what I believe @Mr. Bills used:
HELLA 002395031 Vision Plus 178mm H4 High/Low Beam Conversion Headlamp https://www.amazon.com/dp/B001G76Q2W/?tag=wranglerorg-20
Yes, that is the link for the single housing. The price varies from week to week. I paid $33.19 each for my housings.
