Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
Okay maybe that got you interested. So here is the deal.
I have a ORO AiRock air bag system that I want to install a 3 & 4 link suspension on. When driving on the road it has a 3-4" lift and then when off-road it is between 4-5" of lift. So how do I try and setup my links? I know it would be a lot easier for me to switch back to coil springs or coilovers but I need the variable height that the air bags allow me. I am a lower right leg amputee and being able to lower the rig down helps in getting in and out.
This is on a 1997 TJ and I am going to stretch the rear 4-5" and the front 2-3". I know some say this much stretch isn't enough but I have watch TJ's that were stretched out to about 100" WB and felt they worked better off-road and so did those owners.
But what are all these height changes going to do with my numbers? Do I just build it to work at the off-road height and not worry about on the street? I am not wanting to build this with really long arm but more of a mid arm type suspension. I'd like to try and keep my arms 30" or less.
I am running a Ford HP44 in the front and a Tera CRD60 rear. So both axles are high pinion which will help with the driveline angles. I'm currently running a TSL SX 38x12.5x16.5 which once mounted work out to be a 37" tall tire.
For those of you who have not seen the Off-Road Only AiRock system here is some shots of the main parts.
This is the computer that does all the controlling of the AiRock system. The plug on the side is for the wiring harness that goes to 4 height sensors, in cab controller and to the battery for power. The one air fitting on the side is the input and from there the air goes out thru 4 ports on the top that control the air in the air bags.
There are also solenoids inside that send the air to the bags.
You can see the 4 air ports on the top which go to the air bags that have replaced the stock coil springs. This is the side where the solenoid valves are located.
The computer is on this side. It is a active air bag suspension so it will level the Jeep if you have gear in the back or a trailer hooked to the rear. In highway mode which is from 20-50 MPH it will also put air into the airbags to help control body roll. Above 50 MPH it goes into freeway mode it will keep the Jeep level.
Below 20 MPH you are in manual mode. You can adjust the height, lean left or right and so on. In off-road mode your have full control of the air bags and can rock forward where the rear is raised and front lowered for climbing hills. Or rock back where the front is raised and rear lowered for going done steep inclines.
When on sidehills you can lean to the left or right to make it not so bad.
All this is controlled with dash mounted controller.
And on the rear of the controller is 3 plugs. The one on the right is used to connect it to the computer. The serial port is for updates. Not sure what the other is for.
Here is a video of the AiRock in demo mode going thru it's paces.
I have looked at the Savvy mid arm kit and would love to be able to use it but Savvy and Blaine have spent a lot of time to make this kit work within certain parameters and I don't think from what I have read that it would be a good fit. I wish it was as I feel it is a GREAT suspension kit. Also because of the stretch I am wanting to do I think I would just end up ruining this kit.
Now I know it has been discussed a lot that the 3 & 4 link calculators only give a baseline to go off of. But once the vehicle starts moving all those numbers get thrown out the window. But they do help in the design but until I get it built and try it out there isn't anyway of knowing if it will work. I've been looking at using either the GenRight brackets or the TMR brackets for the links. On the frame end for the lower links I have to use a end that will not allow the tube of the link to roll very much to not damage the height sensors. So either a bushing or a Johnny Joint will work from what ORO has told me. On the axle I can use whatever I want and the same with the upper link ends. This is a height sensor on the Nth Degree longarm.
The complete AiRock system
6" lift airbags. They also offer a shortarm 4" kit.
Lets hear your thoughts and ideas.
