Pretty sure I have a dropped pitman arm. I know I need a stock one, if so. Can someone verify this one is dropped?
edit: 3.5" lift
edit: 3.5" lift
Why does it look like I'm seeing two track bars though? What the hell is that all about?
It's one of those funny track bar braces from the early days. The track bar is also dropped, which requires the dropped pitman arm.
The upper one attaches to the frame on the opposite side. Similar to this from Full Traction...It doesn’t look to you like there are two track bar rods though, one on top of the other?
More pics. Do I need to start ripping this thing out? It works pretty well.
View attachment 93032View attachment 93033
It is not a double track bar. It is a pair of braces for a lowered trackbar mount reusing the stock trackbar.Wow, this is unlike anything I've seen before.
@mrblaine, what's the reason for double track bars like this?
So, They put two track bars/braces on for problems for the dropped pitman? I feel like I need/want to simplify this back to something I can understand...
After looking more closely, I see the stock track bar, and those appear to be two braces for the track bar mount.
It makes you wonder if the second brace was added to solve a problem that the first brace couldn't address. Maybe a third brace is needed?![]()
Ok. So the plan is to do the pitman arm asap. I may leave the rest alone until I feel like opening up that can. Out of curiosity what might be problematic with returning to stock bracing?
Also, pick n pull in Seattle don't have ANY wranglers for the stock pitman...
