Problem with steering locking up
Yes. You need to have it on the ground when doing this.
Have someone get in your vehicle and aggressively turn the steering wheel back and forth while you're underneath the front of the rig. Make sure the vehicle is running while they do this.
Watch the steering move back and forth while you're under there and see if you can visually see anything binding up. It should be really obvious, but my guess is if you do this, you'll find the culprit. I'd almost bet on it.
I have done that Chris and all looks fine. I think the vehicle needs to be in motion for the lockup to take place.
3.75" with 1" spacers
You effectively have 2.75" of backspacing which means the tires are capable of locking up the steering when the locker is engaged unless you have hydro-assist. Do a test, jack up one side, lock the locker and turn the tire by hand until you know it is locked. Then lower it down and without unlocking, start the engine and steer lock to lock.
Report back what happens and if it is very hard to steer, have someone turn the steering wheel while you watch the linkages.
And I expect that is the very reason they were recommending hydro-assist. I will do this test tomorrow and report back.
It wouldn't if the pinch clamps are catching on something on the passenger side when the draglink rolls.
I have checked for clearance there and all is fine. Matter of fact I drive quite a bit with the links disconnected and then they are tucked way up on the side of the frame and I still get lockups.
Get rid of the wheel spacers. They are doing nothing good for your TJ, but they are increasing the front tire's scrub radius which makes steering more difficult. Excessive scrub radius means the tires are being dragged through an arc while turning instead of pivoting in place as happens with the ideal zero scrub radius. Your aftermarket wheel's 3.75" of backspacing (factory is 5.5") added to the scrub radius, adding the spacers further reduced the backspacing to 2.75" which added to the scrub radius problem.
Reactions: Binnie and Chris
It is much easier to say that the tires have to roll as the knuckle turns instead of pivoting on the contact patch.
Even worse, is as you turn the knuckles from left to right, one side rolls forward, the other rolls backward and if they can't roll because the locker is locked, the steering locks up.
Jerry, with the wheels I have I need the spacers for clearance or my 35" tires will rub. But even if I did get rid of the spacers that does not resolve the problem. It this were the problem I would have it all the time and that is not the case. Once I get past the lockup it drives like a dream.
Hey Binnie, glad you found this place! I was wondering how you were making out with this problem, and was hoping you had it figured out. :(
Hi Derek. I am about at the end of my rope. I scared myself so bad the other day I just parked it in my garage and it is going nowhere until the problem is resolved once and for all.
And that makes complete sense to me.
35" tires will not rub with 3.75" of backspacing so long as you have sufficient clearance above the tires via an adequate suspension lift or adequate suspension lift plus body lift combination.
My wheels only have 4" of backspacing with my 35" tires. 3.75" is more than enough for 35's, that is perhaps the most common amount of backspacing for 35's.
Reactions: Binnie
35" tires will not rub with 3.75" of backspacing so long as you have sufficient clearance above the tires via a suspension lift.
Jerry, I think I might be OK up front without the spacers but definitely not on the rear as the tires come in contact with the spring perches on the frame, esp when aired down.
Jerry, I think I might be OK up front without he spacers but definitely not on the rear as the tires come in contact with the spring perches on the frame, esp when aired down.
Not going to happen unless just one side rubs from the axle not being properly centered via the correct length track bar.
As I said earlier I am running 4" of backspacing which positions my tires closer to the spring perches than yours are. Mine do not rub.
Are your axles well centered or are they off to the side?
Reactions: Binnie
Jerry, I am using a Rough Country rear adjustable track bar and I am almost positive the diff is centered. I will go see if I can get a couple pics for you now.
Pictures won't help, just re-read what I said immediately above. Then measure how far the tires protrude out on each side, see if they are the same.
Not to mention my tires occasionally get aired down to 4 psi and they don't rub.
Reactions: Binnie
