Ice chest vs. TJ
Mrgreg66
Hayden, Idaho
Other than building a shelf in the back (which I may do eventually) or buying a $500 ice chest, has anyone found a way to keep their cooler cold when camping in their TJ? I go through a ridiculous amount of ice with the cooler sitting on that hot floor in the back on weekend camping & overlanding trips.
Yeti? Ozark Trail?
I'd get one of those type and set it off the floor , on anything to keep it off a few inches.
Reactions: Mrgreg66
I had my yeti in the back under my tonneau cover when it was 102 last week and drove 160 miles for work, parked in the sun, and drove back. Still had a ton of ice in it that night when I got home and emptied it.
Blocks stay longer but cubes keep my beer colder!
I bit the bullet and got a Yeti. They work but because there is so much mass there it is important to pre-cool them. Once they are fully cooled they go through little ice. I have been on multiple day camping trips and never had to add ice when others are getting ice each day. I do think other cheaper brands are almost as good at Yeti though.
I have a huge Coleman extreme that does well also. It would never fit in the TJ though.
I do not have one but I have heard good things about the Ozark at walmart.
If you want to mod yours a bit installing pads at the bottom may help keep it off the tub and allow some airflow under like you see on the yeti coolers.
https://www.amazon.com/dp/B07D57HQWP/?tag=wranglerorg-20
I gave one. Works great. Have to pre cool it!!! Also. Most people put too much in their cooler, leaving not enough room for ice.
Reactions: Mrgreg66
I use a small 26 qt. roto molded cooler from Wally World.
Some things that have worked for me:
1. Use a main cooler and a day cooler. Cold drinks go in the day cooler. The main cooler stays closed, which preserves cold.
2. Pre-cool the cooler. Use block ice. Frozen food also counts as "ice" until it thaws. Fill air gaps with cubes.
3. Don't pour out the cold water from the melted ice. The cold water will keep things cooler than the air that replaces it. If you are concerned about food items being ruined from coming into contact with melted ice use ziplock bags to protect those items.
4. Reflectix or similar foil-backed bubble insulation wrapped around the cooler helps increases the R value. (Some ACE hardware stores sell it by the linear foot.) Anything that keeps the sun off the cooler and heat at bay will work, including an ordinary blanket, jacket, windshield sun shade, etc.
5. Only keep things in the cooler that actually need to be kept cold. In the same vein, beer for the day after tomorrow does not need to be chilled today, especially if you are in terrain where it can be pre-chilled in a cold stream before going into the cooler.
6. Did I say keep the cooler closed? It bears repeating.
On my last trip, mid-80's in the daytime and low 60's at night, with a 5 hour drive in 100 degree heat to get home, my cooler still had enough ice to keep everything cold at the conclusion of the 3rd day. On the prior trip, with cooler temperatures, my ice lasted 4 days. My record with my current cooler is ice into the 5th day, but there were only a few small pieces left - not even enough for a cocktail. Still, not bad for a $78 cooler.
Buy dry ice at your local grocery store. Just wrap it in a towel so it doesn't deep freeze everything. Much more cooling capacity than regular ice.
Also Pelican (same company that makes the cases) also has a cooler line on par with Yeti, minus the cult
Reactions: StG58 and tworley
I use an RTIC, it is identical to a YETI and a fraction of the cost. I only had to refill on ice twice for a week long roadtrip to Moab, Death Valley, and other spots.
I use two coolers, one is the main cooler for drinks and food. The second one is for ice only, I fill it with bags of ice as many as will fit and then top it off with dry ice and DO NOT open it until you need ice. Then remove the ice and close it back up and keep it in the shade. This dry ice trick will keep the ice frozen for a couple of days.
Rumor has it that the Ozark Trail are made the same as a Yeti. Yeti supposedly did not patent something correctly and Ozark Trail exploited it. This was on 60 minutes or something like that.
I'm going camping tonight and I've had 2 frozen gallons of ice in it overnight. I have a ridiculously expensive Orion cooler but this helps with any cooler.
Also, make sure not to put warm drinks into the cooler.
I always pre-chill drinks before putting them in.
Another thing that helps, if you have a chest freezer buy your ice a day or two before and put it in the freezer. Just because water is ice doesn't mean it's as cold as it can be. Ice out of an ice machine is just below it's melting point. A good freezer gets it nearer to 0 deg. F.
I did the opposite when picking up catered meat and filled it with hot water before. Really blew the peoples mind when I got there. They asked if I had a cooler that made things hot. LOL I drained the hot water and dried the cooler a few minutes before picking up the meat.
If my 15 year old Engel died tomorrow it would have cost me $3.44 per month to own.
I bought very, very little ice since I bought the Engel.
It also takes up less space than an equivelent capacity traditional cooler.
I know the initial expense is more but the cost of a Yeti or comparable cooler isn’t exactly cheap.
Reactions: Ehallspqr
The refrigerators are cool, but I can't throw it in my truck, or someone elses truck or move it 100 yards away from the vehicle it's plugged into.
Someday maybe I'll have an overlanding setup with one though. The dryness is pretty sweet.
Edit: FWIW, Yeti aren't US made any more.
