So o decided to replace the factory speakers with some kicker stuff. And I got everything wired in but noticed the passenger front wasn't putting out audio.
SO, I remove the radio to check the wires, all good, the outlet plug has power, checked to make sure my radio fade/balance wasn't out of wack, all good. I break into the speaker pod on the passenger side and found a little capacitor & resistor. Ohm'd them out to 22ohms. Not sure if this is what it's supposed to be. Maybe the capacitor is bad? Could I just snip these components out?
That's the only thing in my inexperienced electrical mind that could possibly solve the problem.
I also reversed polarity to make sure that the speaker was wired up right, did it the same as the driver side, just had to be sure.
Oh, that tape that was covering that capacitor & resistor was no joke
Edit: I thought it might be the speaker itself, but if that were the case, the tweeter on top of the speaker in the pod would still work.
&Is it normal for capacitors & resistors to be wires together like this?
