One at a time
Awesome thread so far, you've really made a lot of improvements to your TJ. I look forward to seeing more.
Looking great! Love the idea about the string bag on the center console!
Thank you!
Glad you are enjoying the posts so far.
regarding the string bag on the center console, I definitely love it. It helps in storing my USB and AUX cables.
Tailgate table for the TJ?
Yes.
I got one $69 from Amazon China version of Terraflex tailgate table.
DEFINITELY worth it.
https://www.amazon.com/dp/B075R75Y83/?tag=wranglerorg-20
you’ll need this instruction file:
https://teraflex.com/file/attachments/580fcee1628fc400881c0243.pdf
I used double-face tape so the table won’t scratch my tailgate door, and to prevent any noise while moving.
check the photos:
you went from not knowing much, to rebuilding your rig in just a few months, that's awesome. and you had your hands in it all. that's gotta make you feel good.
kudos to you!
Reactions: q8ieng
Great job so far.
Thank you!
kudos to you!
Thank you, and yes! I am truly grateful and more attached to my TJ.
The more I know, the more I love it.
Reactions: someguysjeep
These are good things to consider, especially the Molle Pouches (which I got at a good deal! $8.95 for both).
Which I use to store the things I use frequently (knife, cable charge, headlight...etc)
As what I previously wrote that I have changed my sway bars, tie rod and new suspensions and springs.
Also had my tire pressure to 28-29 (which was 35) made big difference!
But still..
I wasn't 100% satisfied, I wanted the TJ to be smoother and better!
So, I went yesterday and purchased the following:
1- New ball joints (they come in a pair, for front tires, total 4 ball joints) - Mopar
2- New Ball Bearings (Mopar)
3- U-Joints for the axle (they are two only)
After I had these replaced, the ride is totally different now.
Softer, and better!
Less noise too.
The mechanic said:
"Your TJ have 160 miles on it, and the ball-joints and u-joints among with the ball bearings are all from the factory's, haven't been changed before!"
A good step to consider.
Small touches, make good impact.
Using survival paracord:
