I think the only option I have left to get rid of driveline vibration is a SS SYE. With a 4" lift and the Savvy under armor tummy tuck I am out of room for adjustments. I was looking at the JB, anyone had luck, no luck, etc. ?
I do have a Tom Woods DS. But between the Savvy under armor and gas tank skid plate my DS angle is still too much. I talked to the guys at Tom Woods and my trans guy and they both agree on way too much angle for my set up. Every thinks I'm crazy because it's a 4" lift and am still having vibration issues with all the right parts but I do.Personally, I would only go with a super-short SYE if I had an extremely tall lift. For most lifts, and I have had up to 5.5" of lift when I had my previous RE lift, a standard SYE works fine. Why go with a standard SYE over a SS SYE? Because a standard SYE still uses the speedometer gear housing and speedometer gears so you don't have to also purchase and install an electronic speedometer calibrator.
Personally, I have been trusting Tom Wood at www.4xshaft.com for about 15 years now. He carries good quality SYE and CV driveshaft kits, and his pre and post sales support is unsurpassed. Plus Tom is just a super nice guy, I finally had the chance to meet him several years ago at a 4x4 show. If you call them, ask for Tom personally and tell them I sent you directly to Tom.![]()
Yes a very good sye. The speedometer isn't an issue either. JB sssye uses a speed sensor that plugs into your existing wiring and a tone ring behind the yoke. It is only off 2 MPH with 33s. I researched a lot before buying this one but after looking at all it offers I thought it was a good fit. I have a 4 inch suspension lift btw. Smoooth.@Kevin E runs one of these JB super short SYEs and has said he's never had an issue with it.
I'll wait for him to chime in.
Other issues other than what?Yes a very good sye. The speedometer isn't an issue either. JB sssye uses a speed sensor that plugs into your existing wiring and a tone ring behind the yoke. It is only off 2 MPH with 33s. I researched a lot before buying this one but after looking at all it offers I thought it was a good fit. I have a 4 inch suspension lift btw. Smoooth. You might have other issues other than
Sorry about that thought I deleted that.Other issues other than what?
I tried calling them today to ask about the speedo but they are only ther Monday-Thursday. I'm hoping a sssye, different track bar mount and seeing if I can get my gas tank back any further will give them room I need. The JB looks solid as ever too. Thanks for chiming in!
Hahaha I get it. So did you go sssye because of similar issues I'm having or just to try it out?Sorry about that thought I deleted that.
Most of my vibrations were tire related. When I bought my Jeep it had a transfer case drop with stock driveline. I thought why not get the shortest sye to have as long as driveshaft as possible. Now my skid is where it belongs. so far so good with ride quality. I do have the JKS rear adjustable trackbar and angled bracket. If you get your parts and gas tank situated you should be good.Hahaha I get it. So did you go sssye because of similar issues I'm having or just to try it out?
If it doesn't work for me it's either get rid of the skid which I really don't want to or go to 3" springs and shocks.... which I also don't really want to lol
I sure as heck hope so. If it doesn't I'm going to see if I can find someone to fab the frame brackets for the Savvy crossmember. If it's not too expensive I'll go that route and then space the skid plate as needed.Most of my vibrations were tire related. When I bought my Jeep it had a transfer case drop with stock driveline. I thought why not get the shortest sye to have as long as driveshaft as possible. Now my skid is where it belongs a day so far so good with ride quality. I do have the JKS rear adjustable trackbar and angled bracket. If you get your parts and gas tank situated you should be good.
I don't believe the 4" lift number is accurate. Could be, but I doubt it.I do have a Tom Woods DS. But between the Savvy under armor and gas tank skid plate my DS angle is still too much. I talked to the guys at Tom Woods and my trans guy and they both agree on way too much angle for my set up. Every thinks I'm crazy because it's a 4" lift and am still having vibration issues with all the right parts but I do.
At this point my options are get rid of the Savvy UA, get rid of the gas tank skid, get a shorter lift, or explore other components such as the super short SYE to give me more room for adjustments.
No, your issues are from combining a lot of things and not making sure ahead of time that they all work together. I designed the Under Armor around the Currie Trackbar, angled mount and the GST is the same. That and there is always a limitation on lift height when it comes to drive shaft angle.So very true! Sounds like you're about to take on some serious stuff!? If you're not having any issues why not just get a normal sssye?
I have a felling most of my issues come from the under armor gas tank skid.
How did you bend it? And yes I am absolutely going to try just the track bar mount before moving into any other options. Mostly the problem is I bought this jeep with everything that's currently on it, therefore I am the new engineer to someone else's re-engineered cluster F lol.I don't believe the 4" lift number is accurate. Could be, but I doubt it.
Get me a dimension from the bottom of the front spring on the driver's side front to the bottom of the isolator. 4" of lift puts that number right at 16".
Get the angled trackbar mount before you move anything. It makes a big difference. No need to move the tank at all. Simply drop the trackbar and add some forward bend to it where it rubs. I just did a JKS bar a couple of days ago that was set up the same way as yours. The bend over the exhaust was hitting on full stuff, we added some bend past it so when the axle was all the way up, the bend over the exhaust didn't go up as high. It was hitting on the crossmember where the bolts are for the gas tank skid. We added some bend and moved that section of the bar forward and then bent it back closer to the mount. The main reason the Currie bar clears as well as it does is I bent one up and sent it over to them to help with the design.
