Hey everyone! I am brand new to your forum here and pretty new to the Jeep world overall (just a few months). I picked up my 2002 TJ 4.0L automatic earlier this year and have spent quite a bit of money and time working on it. It only has just over 78,000 miles.
The engine had a ticking noise from the front/top of the engine when I bought it, but after treating the oil with Sea Foam, changing the oil and adding Lucas, changing the alternator and serpentine belt, the ticking went away.
BUT, after clearing up that ticking, I was able to hear a new noise that I couldn't hear before: a knocking coming from underneath the engine. It sounds like it is coming from the back of the oil pan/flex plate area. I have done a ton of research online and posted some things over on Jeep Forum, but I wanted to post here to see if my fellow TJ owners would have some more specific thoughts. I've read a ton of posts, many here, but I'm still not confident on what this sound could be.
Various shops have looked at it while doing other things for me (changing gears, assessing a transmission problem I'm working on) and they all seem to have different opinions like piston slap, main bearings, rod bearings.
The sound is not there when I first turn on the engine, but it shows up after about 60 seconds. It goes away when the engine is under load or when the RPMs get up to normal driving range. The oil pressure seems to stay constant.
If it was a main bearing or rod bearing, wouldn't the oil pressure be low?
I have checked, removed, and re-installed the torque-converter bolts and that didn't change things.
I'm really leaning towards a cracked flex-plate, but for some reason these shops I've been to don't seem to think that's it. I've watched a ton of videos on youtube about rod knock and they all seem to be very loud and audible from the top of the engine; mine you can't even hardly hear unless you stick your head underneath the Jeep (where it's pretty noticeable). I found a series of videos from a guy with an older Cherokee and the sound in his video I swear sounds a lot like mine and he ended up changing his flex plate.
I did notice a possible exhaust leak when I was looking around with a flashlight under the engine. Looks like it was just above the cats.
So, any advice guys? Any way to rule out bearing knocks or flex plate issues? Could it actually be an exhaust leak? Anyone else experience this?
This is it:
This is it:
