Suggestions for a minimalist front bumper?
Logos don't bother me, I kind of like it and will probably play it up a bit. Probably put a red back plate behind it to make it "pop" out even more. If it were "ShittyBuilt", I'd probably be hiding it all together, but Motobilt is good stuff.
I also am currently running the stock bumper trimmed. Can put my winch and winch plate on as needed.
Something I recently learned about the factory bumper is that the bottom lip wraps up to contact the crossmember tube, adding a considerable amount of structural support to the bumper. Except for Savvy, I'm not aware of another bumper that copies this detail.
Reactions: psrivats and pagrey
I'm torn between the Savy Aluminum bumper and the UCF ones, mainly the high clearance one. The main drawback for the high clearance one is price. I don't care for the stock sway bar, so that's a non-issue, but it's like another $150+ vs some of the other options.
Reactions: D M
The only thing common between UCF and Savvy is the aluminum.
Among other things. Correct bends for the material, substantially larger winch deck, far more structural support.
I obviously misinterpreted your last post. Aluminum being the only thing they share;) I knew better
Reactions: jjvw
There's only 1 photo of the Savy on their site that I could tell, so it looks very similar to the cheaper UCF, which looks bent with descent radi bends. The high clearance, now that you mention looks welded. Thanks for pointing that out. The Savy it is, pretty easy then, but I do wish there would be some better photos and maybe showing some of the structure.
Reactions: Nickgsjeep
I just ordered both savvy bumpers front and rear last week. Now for the wait 🧐
Here is a picture of it from fourwheeler.com. Exactly how I want my front setup. Clean classic style
What's the wait time? I'm thinking maybe the fall before I order the front one. Not sure about the rear yet.
Im not going to put a number on it with how variable the situation is. I’m under the impression it’s not going to be soon. @mrblaine may have more input but I mentally prepared myself for a long wait period.
