I may need a new dash speaker
Got another question.
I went ahead and replaced my roll bar speakers with the Polk DB series. Just kept the standard size.
I'm going to replace the dash speakers next, with Polk as well. Going with 5.25".
And then I'll replace the subwoofer, with Polk.
My question is, since these replacement speakers, with I'm assuming are better than the stock ones, are 90-91 DB sensitivity, is there any type of replacement stereo I should look for? I'd like to upgrade it as well.
I've been pretty pleased with the Kenwood I got for Xmas.
The Bluetooth works great, and it has plenty of fine tuning features. It drives my 5.25 up front and 6.5's in the sound pods very well. For add bass I teamed it up with a Kenwood amp to run a 8" subwoofer in the center console.
I tucked it away under the steering column.
Decide on your usage and look around, there lots of options. I run a Sony media player in mine, no cd player, since I stream Amazon/Pandora 99.9% of the time. That and no cd's to stash away.
Sony has a new head unit with 40 RMS watts per channel which is double the average power. It has the other usual goodies like Bluetooth etc. I'd replace my current Sony with it if I had the extra cash
Will your dash support a 5.25? I know a 4x6 will work. I have Polk in both dash and sound bar. The great thing about them is they are water-resistant. Also, consider with a new head unit water resistance on the circuit board there as well. I recently purchased this JVC https://www.crutchfield.com/p_105KDX33MB/JVC-KD-X33MBS.html?tp=72453&avf=Y that is also water resistant. My review is the top one for this item. Not as much RMS as the 40w one Jerry mentioned, but at 22RMS x 4 it is sufficient for my highs and mids. Of course, you can always add an amp if you really want more power there. The sub can be powered separately. As you look for a head unit consider whether you want pre-amps for your sub. I much prefer this over wiring into the rear speakers. Also, consider a head unit that has a white background with black letters. This comes in handy when it's summertime and you have the top off. Otherwise the words wash out in the sunlight. Crutchfield (love them or hate them) has great customer service. Call during install and they will help with anything quick. I've done my own for years so if you have problems let me know...
Also, for sub, not sure what you are going for. In a TJ you know that space is a problem. I mounted a self-contained powered subwoofer underneath the rear seat (ON THE BOTTOM) so I can still remove the seat after unplugging two simple wires. It is totally concealed from view, sounds great (to me) but I'm not looking to blow the doors off. I just want the full orb of sound. And it actually sounds awesome. It's the Rockford Fosgate PS-8 and I'm surprised at how low it hits. It is comparable to the Kicker in the same size but on Amazon you can get it for $189. Don't bother with the Sound Ordnance made by Crutchfield unless you just want to save $40. Otherwise, you can always go bigger by filling up the trunk of your TJ!
If you do have the console sub, it's not a true sub to audiophiles. Not that it could not enhance the system. But you need at least an 8". I can post pics of my install if you have any urge to go that route. My head unit, replacement polks in dash, sound bar and the compact powered sub came out to $450 DIY.
Jeep was being conservative with a 6" sub. A 8" sub would have fit with the volume provided. I am no audiophile by any stretch, but I do likes me some good, clean, tight bass music, so I tried to adapt my sucky ass TJ sound system into something that remotely resembles decent sound quality. I'm pretty close to achieving this, but it wasn't easy.
Newbie question please. My stock 2005 TJ's CD player did not come with a sub. The console looks like its designed for one on the outside, but the 'vents' don't go through to the inside. Plus it doesn't seem that anything inside is removable for a speaker. I am a bit confused on how to upgrade. Is there a wiring harness for an amp and sub under my console? Any info would be appreciated. (Not trying to hijack the thread, just piggy back on it...lol) Thanks.
Sent from my SM-G928V using Tapatalk
I have the exact same center console on my 2005 Wrangler X. It appears on the outside that you can add a subwoofer by removing the screws. However, as you noticed, the inside of the console is solid. You would have to extensively modify the inside of the console. The sub you would add has to be slimline. I would measure myself and check around. Also, you really need the console enclosed. Just shutting the lid really doesn't do that. Plus you'd lose the console storage. If you sealed it you'd stil need an amp and a place to mount it.
One option is to replace the console with one that accommodates a sub. This is an expensive route. Here's one.
https://www.4wd.com/Jeep-Interior-P...id=TFY066-01&gclid=CL21so302tICFV25wAodkyMJpg
It's far cheaper, easier and better sounding to get a compact powered sub and mount under the rear seat. Here's a great one.
https://www.amazon.com/gp/product/B00Y3WKUX8/?tag=wranglerorg-20
Of course, either way with the stock CD player you'll have to run a line out option and splice into your rear speaker line to get a signal to the amp. It's better to replace the CD player with one that has sub pre-outs for RCA connectors. They are pretty cheap these days. Try Crutchfield online.
Reactions: LeePTI
It's not the easiest thing to do, but you can add a slimline 8" sub and utilize that storage pocket into an enclosure for the sub. You will have to fabricate a top for the enclosure to seal it off. I cut one out of 3/4" MDF and epoxied it to the enclosure. You'll also need to brace the speaker opening to provide some support for the sub. Then you'll need an amp to power the sub. Like I said, not easy, but doable. JMT's idea would be much easier. Here's some pics of what I did...
Reactions: LeePTI
The factory dash speaker is 4x6 but you can get adapter brackets to run a 5.25". The 5.25 gives a much better selection of quality speakers. If you have the sound bar or pods, you can replace them with 6.5/6.75 instead of the stock 5.25". They just screw to the top of the box. I also used sealing tape around the edges so it sealed better.
