I have WJ knuckles on my TJ. Will a set of WJ rotors work if I have the centers bored out and have the 5x4.5 patterns machined to match the diameter dimensions on the rotors that were supplied with the small hub Yukon kit?The rotor is a stock full cast rotor from a 90- early 99 Wrangler. The lock out hub is what is known as the "Ranger" hub since it the same in appearance as the stock locking hub on some of the Rangers. The center bore is opened up to just snugly fit the back section of the bearing hub and then the rotor is mounted to the hub flange with the press in lug studs.
