Illinois Chicago Rust Repair? Rotted Floor Supports
Warrior4284
Chicago
Does anybody know of a mechanic in the Chicago area that will do body and frame repairs on TJ's?
My body mounts are in bad shape all around and need to be replaced and I also need some new floor supports welded in as mine have all but disintegrated at this point. Looking fro a contact that could possibly install the floor support caps - https://www.autorust.com/product/full-length-floor-channel-subframe-set-wrangler-tj-97-06/
Any Help would be appreciated
You may be better off with a new Jeep. That much bodyshop work is easily over $5 grand in my area. Easily over by a few more $ grand.
Yep - might get a new Jeep, want to see what it would cost to repair though. Been riding around for a few years with the rotted floor supports, makes for a rough ride. Hoping I can get a shop to just throw these over the top of the old floor supports and weld them in. Frame is still in good shape
You might call one of the local BODY SHOPS. I had to replace both rails on my jeep from sring to spring and with them picking it up and trailering it 200 miles, with parts was $3k in Kansas.
Did you have any luck finding someone? Same situation in Chicago....
Did you have any luck? Looking for a shop as well.
