for science..
for science..
Doors have amazing resultsAnd done. Dynamat xtreme bulk pack (9 peices) covers the tub really well. If I'm still not happy with the noise I'll get enough to do the doors and tail gate. Had enough off cuts to put some in with the speakers too.
Good lookin Jeep! What is tummy tuck, removing the running boards and molding?Finally got the tummy tuck done!
High clearance skid plate.Good lookin Jeep! What is tummy tuck, removing the running boards and molding?
Well, I guess that and a few other things, like a Savvy 1.25” body lift, MORE motor mounts, MORE steering riser bracket, and a UCF transfer case skid. Prior to the tummy tuck, you can see the OEM transfer case skid well below the frame and there’s actually daylight between the engine skid and the body. Everything got tucked up nice, giving the Jeep significantly more clearance compared to the before pic:
Wait till you take the doors off for the first time! You’ll be giggling like a school girlTook off the soft top for the first time. Drove around with a stupid grin. Most fun I’ve had in awhile.
That is a really nice looking Jeep, or fab tyre carrier?
Watch those brackets when you put your doors back on! You WILL chip paint.
I bought those POS' the angle is HORRIBLE. I had another set that mount to the door hinge from Ebay and merged the two together. I'm happy now.
Highly suggest you get the no door mirrors before doing so. I drove it once with no doors. Super fun but even I thought it was sorta dangerous.Wait till you take the doors off for the first time! You’ll be giggling like a school girl![]()
I like the round but that is just personal preference, I don’t know if one is better than the other. I tightened the three Phillips head screws really tight after I adjusted the mirrors and they haven’t budged. I don’t know anything about the stubby’sI was just about to order. Do you think the rectangle version would be a better choice? What about a stubby?
Swapped my inner door handles with new Dorman replacements. Also installed my new clear turn signal lenses. Clear side markers need to wait for the flares to be painted.
Need to pull valve cover and check for loose rockers. Has a slight tick at higher RPM. Nothing at idle. Might just replace all rockers and seats if I find any wear.
Have a media blaster nearby? I had my front axle media blasted then chemical dipped for $40. Definitely worth it IMO.
