Anyone ever run into this issue when installing their RockJock Antirock?
Chris
Administrator
Staff Member
Gillette, WY
I'm installing the new RockJock (the redesigned Currie Antirock) and ran into this issue:
The threaded end of the helm joint is too big for the stock sway bar mounting point on the axle housing.
I've installed TWO Currie Antirocks before on previous TJs and never had this issue.
So either RockJock (Currie) changed the design on this new Antirock, or something is up with my TJ.
Anyone know what size drill bit I need to go buy now?
  • Wow
Reactions: Apparition
It would appear they made the threaded end of the heim joint larger.
I'd call them up. They answered the phone right way the other day. (714) 367-1580
Nevermind Blaine gave you the answer.
Just installed the new version on mine a month or so ago and it fit just fine. Weird.
1/2-20 is the stud, so a 1/2" drill bit. Check that by the nut hex size which should be 3/4" Inner flat is 5/8".
In case anyone is wondering, he's not looking this stuff up before he posts hardware sizes. I've never known Blaine to not know the size of the various fasteners used in our Jeeps off the top of his head. Even his wife Kat told me the size of a wrench I needed one day as she walked by me as I was working on something. One of my control arm bolts worked its way out while at Johnson Valley with friends a few months back and once I got to town, I called Blaine and without a moment's hesitation gave me both the SAE and metric equivalent size of the required bolt off the top of his head. Some people got it and some people (me) don't.
Okay, so either I got some different parts or my TJ is somehow different than others :LOL:
Not that I mind drilling, I'm just curious.
I work with some production & design engineers like that. I'm out in the field, & sometimes I run into a problem that for the life of my I can't work through and I call them for help with what I think is the most obscure one-off question.. Without missing a beat or looking anything up they'll just rattle off the pin diameter, grip length, mating surface composition, torque process & value, max-blueprint hole size, part number & vendor. It's impressive.
When you've messed with something as much as those guys have (Blaine too), I suppose it becomes second nature.
Reactions: qslim
For sure. I remember wrench sizes pretty well because I just remember numbers in general.
I think it also helps that I'm so bad at knowing the size by looking at it. By the time I've found the right one it's hammered into my head and will be there forever, then gets even more cemented in when I need it again 10 minutes later and spend half an hour turning my garage upside down to find it. . 🤣
