Thanks to @CodaMan for laying the ground work for this one as he inspired me to write this thread as a resource for others.
The issue is that I see people constantly posting about purchasing the OME 2.5" lift, Rough County 2.5" lifts, or others "lift kits". In reality, I think you can save a lot of money and get better quality parts if you piece together your own lift. The problem I have with the OME lift is that the newer shocks they switched to years ago ride terrible in comparison to the shocks they used to use. Rough Country is the same way in that the shocks they include in their kits are absolutely terrible.
For the most part, springs are springs, but the shocks are really what's going to affect your ride quality. That being said, below you'll find a perfect recipe for a 2" lift that uses quality parts and won't break the bank. In addition, this setup shouldn't require a transfer case drop in most cases.
Hopefully this thread serves as a resource to others. You're much better off piecing your own lift together as oppose to buying a "kit" in most cases.
- Rancho RS5000X Shocks 0-2" (2 Front) — RS55128
- Rancho RS5000X Shocks 0-2" (2 Rear) — RS55240
- BDS 2" Front Springs
- BDS 2" Rear Springs
- OME Rear Track Bar Reloaction Bracket — ARB FKWTJ02
- Daystar.75" Spacers — KJ09108BK (note: only used above front springs for leveling, if you don't care about being level, you don't need these)
