k752 fits in a currie track bar but it has very little rubber due to the giant sleeve. But it works
but the k5272 is the magic bushing
So to confirm, the Moog k3147 should be the better bushing to replace the axle side bushing on the currie trackbar, correct? And theoretically I should just be able to press the old one out and then press the new moog k3147 in?
The CE-9120TJS already uses the k3147
They likely make a JJ that will fit but then we have the same problem as others, how to stop the bar from flopping around.If these free spinning sleeves don't suffer the same fate as a heim joint, then that would be something. Currie figured it out by adding preload to the center ball. But a JJ won't fit in the axle side.
Couldn't that easily be solved by simply using a washer and bushing with a smaller ID hole to restrict the movement of the ball?They likely make a JJ that will fit but then we have the same problem as others, how to stop the bar from flopping around.
Why?Couldn't that easily be solved by simply using a washer and bushing with a smaller ID hole to restrict the movement of the ball?
To stop the bar from flopping. I'm not saying that a JJ would be better than a bushing on the axle end. I'm just answering the question of how you could use a modified JJ on the axle end and still keep the bar from flopping. Whether or not that actually serves a real purpose can be debated by others. I don't really see that need.Why?
The big issue with the rear one is if it flops back, it can get under the crossmember and do some damage.I have wondered why they couldn't solve the front the same way they did the rear with the wobble stopper washers. But I've also never seen a rear Currie track bar in person to see how much they restrict the flopping.
Why do you want to move to a smaller bolt?Does the k3147 fit in the rear OEM style track bar?
I don’t. The bushings are shot and I cannot find the correct ones for the rear other than replacing the whole bar. Which I can...but the single element vs dual element discussion me think there is a better solution instead of replacing the whole bar.Why do you want to move to a smaller bolt?
I can now confirm the bushings for the rear track bar are the same as the front. If I were gonna replace the rear track bar, I’d just replace the bushings. I ordered a rear track bar and then front bushings and it was the same model number on the existing front bushing and the new rear.I'm looking forward to hearing what the OEM rear bushings are. Then I can change those out to right away too. Thanks.
So the rear also uses the k3147?I can now confirm the bushings for the rear track bar are the same as the front. If I were gonna replace the rear track bar, I’d just replace the bushings. I ordered a rear track bar and then front bushings and it was the same model number on the existing front bushing and the new rear.
I would suspect so. The bolt goes through and then clevite model number is the same.So the rear also uses the k3147?
