5-Channel Amp Mounting Locations?
Oh no, you had the power into the amps ground and vice-versa? You had a nice Alpine amp as well. Ouch! Hopefully it was not a new amplifier. Did you look at the amp's two 30A fuses to rule that out?
I visually inspected the 30A fuses, nothing more. In theory they should be fine because the output wasn't shorted, the input voltage was messed. I wire the battery to ground and vice-versa. I can't believe I was that dumb when I was so careful about everything else. The amp was purchased new way back in 2014 but never installed until now, so no warranty either, even though it was my fault. We'll see if I can send it in and if it isn't totally pooched.
That blows (no pun intended)...maybe you can find a used one on Ebay, make a low offer and see what happens.
https://rover.ebay.com/rover/1/711-...0001&campid=5337789113&icep_item=164217105923
Crutchfield gave me a local repair center that does all the Alpine warranty service in my relative area. I am going to take it to them and see what they say. My guess is these amps have a Switching PSU, so chances are it is just a fried semi in the PSU that needs replacing, if it still exists.
Reactions: skrelnik
I was actually looking at this one
https://hifonics.com/tps-a600-5/
Do you have speakers already selected?
Three different amps going on.
Hifonics
  • POWER @ 2-OHMS
    4 x 80W + 1 x 200W
  • POWER @ 4-OHMS
    4 x 40W + 1 x 100W
Soundsteam
  • 60 watts RMS x 4 at + 200 watts RMS x 1 at 4 ohms
  • 80 watts RMS x 4 at + 350 watts RMS x 1 at 2 ohms
Cerwin
  • RMS Power Rating, Ch 1 - 4:
    • 4 ohms: 80 watts x 4 chan.
    • 2 ohms: 150 watts x 4 chan.
    • Bridged, 4 ohms: 300 watts x 2 chan.
  • RMS Power Rating, Sub Ch:
    • 4 ohms: 200 watts x 1 chan.
    • 2 ohms: 350 watts x 1 chan.
    • 1 ohm: ——————N/A———
Hifonics
  • POWER @ 2-OHMS
    4 x 80W + 1 x 200W
  • POWER @ 4-OHMS
    4 x 40W + 1 x 100W
Soundsteam
Cerwin
Yes i already have four skar audio https://www.skaraudio.com/collectio...products/tx525-5-25-inch-coaxial-car-speakers
and plan on getting a kicker 6.75 dvc 1 ohm https://www.kicker.com/comp-rt-6-75-1-ohm-subwoofer
The Skars are rated 4 ohm and 80 watt RMS. The Hifonics amp pushes out 40 watts at 4 ohm, Soundsteam is 60 watts and Cerwin is 80 Watts, both at 4 ohm RMS.
That Kicker sub is a great choice, but a Kicker 1 ohm wired in series will pull 2 ohms, Hifonics is rated at 200 watts and the others at 350 watts. The Kicker wants between 150 watts and 300 watts, and it does play nice bass for its size.
That Hifonics amp may be pushed too it's limits and distort the sound. I would opt for the Soundsteam or Cerwin over the Hifonics.
The skar are actually rated at 40 rms per speaker and i have a SMD DD-1 to set the gains properly on the amplifier i was looking at the soundstream amp as well also this dual 5 channel as well DMA5600 http://www.dualav.com/marineaudio/amplifiers.php
And was looking at the Skar evl 6.5" dvc 4-ohm https://www.skaraudio.com/products/evl-65-inch-car-subwoofer
And Audio legion 6.5" dvc 4-ohm https://www.audiolegionusa.com/products/s2506-6-5-inch-car-subwoofer
But not sure if i can make them fit the factory subwoofer console
Good call, it says per pair which I overlooked. I'd still go with Soundsteam or Cerwin since the prices are relatively the same. Better name brand, and with car audio, those off brand names generally produce fake numbers.
Hifonics is a solid name, but I would be wary to use that amp with those speakers. I would want more juice. I currently have a Soundstream marine amplifer and it is doing a great job. I previously had a Soundigital and that thing blew, was poorly made, so that was the issue.
Reactions: lilflippy
Whatcha think about the dual marine amp?
What sub do you have?
In my center console I installed an 8" Ground Zero mid woofer, and I also have a removable box in the cargo area that holds two 10" woofers.
The Kicker 6.75" is a great sub, good price, fits and pounds for it size. I would recommend that one all day long to an owner of a TJ that wants a simple and good sub upgrade. That with your four Skars will be a solid set-up.
If you are thinking of another direction ask away.
